Weight of an empty reefer rig
Discussion in 'Refrigerated Trucking Forum' started by Brucesmith, Mar 20, 2017.
  1. Brucesmith
    Brucesmith Heavy Load Member
    736
    505
    Jun 16, 2012
    How much heavier is a reefer trailer than a dry van? I realize that every truck has a different weight but how much can you put into a reefer trailer pulled by say a Cascadia?
  3. Ryan423
    Ryan423 Light Load Member
    226
    381
    Mar 18, 2016
    California
    About 45000 lbs
    kbarttt Thanks this.
  4. Steel Dragon
    Steel Dragon Road Train Member
    2,681
    2,833
    Nov 23, 2015
    My reefer trailer says 15,500 pounds, add truck 20,000, gives you 35,500.
    Leaves you max 45,000.
  5. The Kraut
    The Kraut Medium Load Member
    597
    1,560
    Sep 5, 2013
    Land of Enchantment
    Volvo D13 midroof with APU and Great Dane reefer 35000, can load 45000 lbs
  6. Brucesmith
    736
    505
    Jun 16, 2012
  7. rocknroll81
    rocknroll81 Road Train Member
    1,363
    1,005
    Sep 29, 2010
    West Allis Wi.
    2017 Cascadia dd15, Comfort Pro APU, Utility Reefer w/Carrier unit, Empty Weight 34,000.
    Richtaco Thanks this.
  8. rollin coal
    rollin coal Road Train Member
    13,451
    27,430
    Mar 29, 2008
    TN
    Every tractor and trailer is different. With tanks full of fuel I can easily scale 45,000 lbs with the reefer I pull. With full tanks pulling my dry van I can easily scale 47,000 lbs.
    I have a T600 and for a truck with a heavy 15L CAT motor it's relatively lightweight. A buddy of mine has a flat top FLD. He has a reefer trailer almost identical to mine but he could easily scale 47,000 lbs in his reefer.
  9. passport220
    passport220 Road Train Member
    1,463
    2,073
    Oct 9, 2012
    Des Moines, IA
  10. Mullet_Head87
    Mullet_Head87 Medium Load Member
    453
    548
    Apr 19, 2014
    Clearwater
    Great Dane trailers are heavier but my cascadia full of fuel is a little under 35000 empty with utility trailer reefer.
  11. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,139
    Mar 5, 2016
    White County, Arkansas
    Hop onto a cat scale and find out.
    With that said, I think the great dane 48 foot was 14500 empty
    The tractor would be around 17000 (FLD 120) add the two together... 31500. Add 1000 for pallets in the nose and another 1000 for driver or drivers and his stuff.
    Usually load 48000 in the box but check fuel tanks against any scales you will cross. It's close to right about 80000.
    Today's 53 foot trailers with reefer will be a little bit heavier. No pallets in the nose though so... it's a trade off.
