What’s the minimum tonnage you’ll accept?
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by Frank Speak, Oct 19, 2018.
  1. Frank Speak
    Frank Speak Road Train Member
    4,532
    13,875
    May 3, 2016
    we go to a couple of places where you get an m/t weight and then scale again when you’re loaded.
    I can haul 26 tons, but if I’m at anything over 24, I’m not going back for more. Not worth the time wasted to me.
    Crude Truckin', 06driver and x1Heavy Thank this.
  3. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,139
    Mar 5, 2016
    White County, Arkansas
    Did you get your profits erased by overweight by two tons recently? I have more questions, some of which are painful and obvious. Not to mention bordering on stupid. It will help myself and others to understand the overall situation.
  4. Rubber duck kw
    6,092
    17,686
    Dec 9, 2017
    Depends what I'm hauling and how well it's paying. Sunflowers I've never managed to get more about 24 ton on, something that I can actually get some weight on, like corn or beans, I aim for about 29 or 30.
    Frank Speak Thanks this.
  5. Frank Speak
    4,532
    13,875
    May 3, 2016
    Most places I go, I sit on a scale while getting loaded and they’ll load right up to 80k.
    There are a couple where the scale isn’t in the silo. So you get an empty weight, drive to the silo, get loaded by telling the loader the empty weight and then they time the load. Example, you tell them 28k and then they load for 3 mins.
    It’s pretty accurate most of the time, but sometimes they’re off. Sometimes they’ll over load and that’s fine as long as I’m not heading around any scales. Other times they under load.
    As long as it’s 24 tons, I take it and run rather than going back. It’s not worth my time. Less than 24, I go back because that is worth my time.
    Hopefully, that makes more sense.
    06driver Thanks this.
  6. skinnytrucker
    skinnytrucker Heavy Load Member
    856
    453
    Jan 24, 2009
    U.P. of Michigan
  7. 06driver
    06driver Road Train Member
    2,436
    3,434
    May 28, 2017
    Don't do weight anymore but when I did I could hold 24 5 on a live floor. At the citrus plants it was kind of hit and miss. Did the best I could with air gage on the truck but if I hit 22.5 (anything over 76k) I rolled. Way to much headache to get back around and finagle without going over. And you did not leave over weight.
  8. s0231198
    s0231198 Light Load Member
    143
    245
    Aug 23, 2008
    For me, I can haul 27 ton in a pneumatic tank, and be just under 80k, some times we do as you do and not load on a scale, when it comes to loading like that, I use my air gauge on my trailer as it reacts better and faster than the digital gauge in the truck for those axles and is usually pretty accurate to what I have to load to, as I am usually pretty close to loading 77,500-78,000 almost every time. As to your question, and being company driver, they usually don't say much to us when they know we don't load on a scale at some places, but want us to try to load atleast 24 ton. It depends on how much we loaded the first time around, if it's usually anything under 23.5 ton I will go back and load some more, but that is depending on how far you have to go to get loaded, if you have to drive a mile around the plant just to get back to the silo again after you have to close everything up just to drive to the scale, or if there is a bunch of trucks in line already to get loaded, and takes a while to load, forget it that's what it's going out as. At one of the places I load at, it can take them 20-30 mins to load just one truck, so I am not gonna spend 2 hrs just to get an extra ton or 2 to run bc you have to wait in line again. The places we deliver to don't say anything, bc the other companies that haul to them have heavy sleepers on them, and some of them can only haul 24 ton and be just under 80k, so at times they only bring 22 ton.
  9. REO6205
    REO6205 Road Train Member
    13,171
    60,501
    Feb 15, 2014
    California.
    If you go back and top off two or three loads a day and the time you've spent winds up costing you another whole load you've just shot yourself in the foot.
    If you're paid by the hour what the company gains in revenue and what it costs them for you to go back and top off is usually an even trade-off. Trade-offs are not profit.
    Load the best you can and run with it.
  10. Dave_in_AZ
    397,511
    I've taken well over a dozen loads in the last year 1500 to 2500 miles that weighed like 600 pounds. Is that bad?
    NightWind Thanks this.
  11. TankerYankr
    TankerYankr Medium Load Member
    303
    470
    Jan 16, 2010
    Central US
    I always figured close, was good enough.
    As I told the loaders, scale person, etc., we're just loading a truck, not building a rocket.
