What do you do if you cant get tandems to slide
Discussion in 'Questions From New Drivers' started by Kolorado, Jul 14, 2021.
  1. Kolorado
    Kolorado Medium Load Member
    524
    787
    Feb 28, 2015
    Colorado/Texas
    Just wondering for future reference!
    This happed the other day but luckily it was a lite load.
    i've heard back up to a curb / hammer to pins
  3. ZVar
    ZVar Road Train Member
    10,911
    23,829
    Sep 10, 2010
    Flint, MI
    Ours are air assist. If the pins don't retract it means either the release valve or air bag is bad. In both cases it's a shop fix and no amount of hammering or curbs or whatever will help.
  4. CargoWahgo
    CargoWahgo Road Train Member
    3,912
    3,945
    Jan 10, 2012
    Louisville, Kentucky
    Look and see if the spring needs hooked back in from underneath. I had to do it plenty of times on cfi's trailers.
    Or you can take it to the shop and they can take three days to get to you to do it.
    ....if you need a day off...
  5. loudtom
    loudtom Road Train Member
    1,717
    2,802
    Aug 26, 2016
    If they're rusted, beat the rails in multiple spots with something heavy to break the bond. Then you can hit them up with a lubricant. I've heard grease and oil based lubricants can attract dirt and grime, which can make it hard to slide again. I've also heard of people using dish soap, which can be reapplied after it washes away. Get some wheel chocks to carry with you, since there may not always be a suitable curb available to use.
  6. smokey12
    smokey12 Road Train Member
    1,641
    2,997
    May 30, 2012
    I use that lubricant stuff u get at the truck stop it's called BLASTER ..comes in a pressurized spray bottle..spray it in all the holes on the tandem, let it soak a minute..if u have to get your mallet and beat moderately on the slide
    .usually always works
  7. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,058
    Nov 18, 2014
    Land of local
    Just for future reference make sure you have the system fully charged before attempting to slide the air assisted pins or they don't like to release
  8. Moosetek13
    Moosetek13 Road Train Member
    14,734
    18,554
    Nov 1, 2010
    Burnsville, MN
    If they are that stuck you will just destroy the chocks. Chocks are not really that strong.
    A couple 4x4's might do it.
  9. truckdriver31
    6,989
    8,352
    Sep 18, 2013
    pull handle as far as you can. put a pair of vice grips on and lock them as closes as you can to the rail. get in truck and wiggle it back and fourth
  10. Lazer
    Lazer Road Train Member
    1,804
    2,880
    Jan 22, 2017
    After the pins are fully retracted, get rolling a little, then quickly pull down on the trailer brake handle, don’t be slipping the clutch.
  11. Harry Flashman
    Harry Flashman Medium Load Member
    510
    1,360
    Oct 4, 2019
    I had air assist with 2 companies, those air assists are pretty weak when it comes to rust. Frequently had to use a hammer.
    Here are the tricks:
    1. Hammer
    2. Curb
    3. Rock the trailer with short sharp acceleration forward, then backward. Important to try both directions.
    4. Make sure your automatic slack adjusters are adjusted by fully pumping the break pedal down several times.
    5. Try a different spot, if the ground isn’t perfectly level, the tandems can sometimes refuse to slide
    Trucker61016, TravR1, Team818 and 5 others Thank this.
