What is the actual difference between fresh and subzero temp in your fuel costs per mile
Discussion in 'Refrigerated Trucking Forum' started by AaronP, Mar 27, 2019.
  1. AaronP
    AaronP Bobtail Member
    34
    58
    Feb 5, 2019
    Settle a bet for me? Thanks in advance.
  3. I glide 47
    I glide 47 Road Train Member
    1,426
    1,523
    Jun 3, 2017
    I think it should be cheaper to maintain 35 rather than minus 10 ,my 2 pennies ,if I helped want my cut
    Balakov100 and AaronP Thank this.
  4. AaronP
    34
    58
    Feb 5, 2019
    Hah! I'm talking in actual dollars, though. Just curious.
  5. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,768
    Mar 5, 2012
    Ontario Canada
    Winter or summer?
    Along i90 or i10?
    It's hard to give an exact answer....
    Summer I actually use more for fresh (42) than frozen (-10) since the produce I haul is generally still warm from the field...
    Winter I can use more if continuous for say lettuce than cycle for frozen... now if the produce is at temp it will use less during summer than trying to keep frozen at -10....
    Clear...?
    AaronP Thanks this.
  6. AaronP
    34
    58
    Feb 5, 2019
    Since I don't pull reefers, not really hah! I guess I was assuming that the ratio between the two would be the same no matter what the outside temp is, or lane, even as the total rises and falls based on factors.
  7. gokiddogo
    8,786
    14,768
    Mar 5, 2012
    Ontario Canada
    Basicly.... the bigger the difference between the temp of the product loaded vs what the set temp is.... then add whatever outside temp is... will determine how much you use...
    If outside = 0f
    Set point -10
    Product -5
    Use hardly any
    Change outside to +90, probably double fuel usage
    Change product temp to warm... triple fuel usage
    It really can swing wildly...
    magoo68, Cat sdp and AaronP Thank this.
  8. lilillill
    lilillill Sarcasm... it's not just for breakfast
    5,642
    13,471
    Nov 7, 2007
    Possum Booger, Alabama
    The colder the ambient temp, the less the reefer, set on cycle, will run for either fresh or frozen. However, there comes a point when the temperature gets close enough to 35° that the unit probably won't run at all on a cooler load set on cycle but it will still cycle on for a frozen load, thus burning more fuel for frozen.
    You'd think the same formula would be true as the ambient temperature reaches -10° or so, except, most reefer haulers, myself included, run the unit on continuous in subzero temps to keep the fuel from gelling up and/or having battery problems.
    So the answer is no, it's not linear.
    AaronP Thanks this.
  9. lilillill
    5,642
    13,471
    Nov 7, 2007
    To answer the real dollars and cents, I'll take a chill load, that can be run on cycle, any day over a frozen. Depending on the ambient temp, it might be a $60 a day difference.
    AaronP and Bean Jr. Thank this.
  10. KB3MMX
    KB3MMX Road Train Member
    3,075
    2,595
    Dec 29, 2014
    Orrstown, PA
    Winter time of year can cross the country -10F cycle on about $50 fuel.
    Coming back with produce on continuous 38F it'll burn about twice that
    So many variables... Reefer brand&model ... Trailer specs ... Climate ... Load required temps ... Mode ... load temps as loaded ... Iced vs not iced.. Etc etc etc
    AaronP Thanks this.
  11. SteveScott
    SteveScott Road Train Member
    4,897
    16,807
    Nov 10, 2015
    It has a lot more to do with cycled vs continuous cooling. Once a temp is reached (regardless if frozen or cold fresh) and the exterior temps aren't too hot, it costs almost nothing in fuel to run in cycled mode. I can go 3 to 4 weeks in cycled mode on a tank of fuel, but only 5 to 6 days in continuous mode. But I have a new trailer and reefer too. Older ones aren't very efficient.
