What type of reefer should I get
Discussion in 'Refrigerated Trucking Forum' started by 97w9, Aug 8, 2024.
  1. 97w9
    97w9 Bobtail Member
    12
    11
    Feb 10, 2024
    I'm looking to purchase a reefer and I can't decide if I want a smooth floor or a corrugated.
    What is the common type that is used if I'm just going to do the load board?
    Or I should say what is the most popular?
    I definitely want to get swing doors no matter what.
    If I go with corrugated can I use a pallet jack on it?
    Also what other features should I look for in a reefer unit?
    I definitely want air suspension, 53/102
    I don't want carb compliant or any kind of emissions.
    Thanks
    motocross25 Thanks this.
  3. motocross25
    motocross25 Road Train Member
    3,868
    11,850
    Sep 23, 2010
    Overland Park, KS
    You could swing a dead cat in the TTR forum and hit people with more reefer knowledge than me, but in my opinion, you want corrugated floors. It helps circulate air flow and if you’re hauling something messy or bloody or both it will channel it away from the product and ideally out the drain holes. I think air chutes are pretty common now if not standard, if not I would think about purchasing a bulk door. If you have 1/2 or 3/4 even of product trailered you can dam it off and not have to cool the whole thing. I guess too it depends on what you’re hauling. I’ve only pulled ice cream spec’d trailers with a little heavier duty insulation and units that could pull down to -20, so if that’s your game you may wanna be mindful of that.
    beastr123 Thanks this.
  4. Opus
    129,097
    Columbian......the good stuff
  5. Blagoje
    Blagoje Medium Load Member
    441
    960
    Jul 14, 2022
    Paris, Illinois
    Great Dane Everest
    goga Thanks this.
  6. Numb
    Numb Crusty Curmudgeon
    4,238
    9,950
    Jan 30, 2012
    Charlotte, N.Carolina
    beat me to it!!
    Opus Thanks this.
  7. 201
    201 Road Train Member
    12,642
    25,975
    Apr 16, 2014
    high plains colorado
    Ha! Bound to happen, but really, depends what you are going to haul. Anything drippy or bloody or liquid or swingin',, I'd go with a metal grooved floor. They are kind of a PITA, though, hard to move pallets around, and cleaning is a hassle, but if you are just hauling boxes or palletized, I'd go with a wood floor. There may be times, you will haul a van load and needs to be secured, or a slip sheet load, doesn't go well on the grooves. Be picky, as there's no shortage of used reefers, and they take a beating. I'd go with a Great Dane, was the standard of the industry for years..
  8. Short Fuse EOD
    2,786
    8,739
    Jul 29, 2015
    Midwest
    Utility Reefer is the most common type in this country. Great Dane is good as well. I own one of each. I’d go with Grooved floor unless you’re doing furniture along with refrigerated loads. Very common amongst reefer haulers that also pull furniture loads. I recommend you Find a good unit for the trailer. A claim can put you out of business. Yes, you can use a pallet jack on groves floor, no problem.
    goga Thanks this.
  9. bad-luck
    bad-luck Road Train Member
    3,378
    6,253
    Nov 16, 2013
    Baltimore, Maryland
    Great dane is the best.
    Second is Utility
    Then all the rest.
    I have a flat floor and I like it, as it is easier to keep clean. You can use a pallet jack in corrugated, but it is easier to move on a flat floor. The newer units are carb compliant, some for life, some only for 3 years.
    Mnmover99 and goga Thank this.
  10. goga
    goga Heavy Load Member
    895
    1,586
    Nov 11, 2021
    Earth..
    It's a reefer, air circulated wrapping around the product. What circulation if product is side loaded and no go on the floor?
  11. Short Fuse EOD
    2,786
    8,739
    Jul 29, 2015
    Midwest
    Grooved floor is helpful with produce. Another thing to think about almost no reefers out there are exactly the same. It’s all How do you spec them. Distance of post, crossmembers, insulation thickness, puncture, guard, side walls or also the roof. The list goes on and on. You can have a Utility that’s light years. Better spec than a great Dane or the other way around. There are some things on my Utility. I like better than all my Dane and then the other way around. The number one selling reefer trailer in the country is Utility. It’s not necessarily because it’s cheaper. Shoot, my Utility is much more expensive than my great Dane. It’s how the trailer was specd. When buying a used Reefer, if you’re trying to figure its specs, Have the dealer run the Vin and look at the build sheet.
