Being a the nerd I am I was watching old marketing VHS tapes reuploaded to YouTube. One of them was from Rockwell transmission. Never heard of them before only ever heard of Spicer and Eaton-Fuller. Then I was on marketplace and seen a ten speed going for 400 dollars. Functional mind you, doesn't pop out of gear and the gearbox looks mostly mint.
Wth happened to rockwell transmission? And why what looks to be a decent trans go for 400 dollars
What's the deal with Rockwell transmissions?
Discussion in 'Ask An Owner Operator' started by Charmeiser, Apr 29, 2025.
Rockwells were pretty much in fleet trucks early on. Self explanatory why they're not desired -
Drove a bunch with a Rockwell.
Never had any trouble out of one.
Bunch of old Freightliner fld120s had them.
Now meritor
Charmeiser and tscottme Thank this. -
Because they ####ing suck, right up there with a maxi torque
Vampire Thanks this. -
my 60 year old father often had to drive that truck, much against his wishes. He was a sales man but they couldn’t keep drivers. He would just leave it in high range and run it like a five speed. Slipping the clutch for half a block to get started. I don’t think we ever even put a clutch in that truck, it #### sure never had a working clutch brake.Sons Hero and hope not dumb twucker Thank this. -
Rockwell makes good axles, not so great transmissions. Eaton was kinda the other way around.
W923 Thanks this. -
Funny thing about it is they are nearly an exact copy of an Eaton fuller…. biggest difference that I’ve noticed is they use silicone instead of gaskets and the shift rails and stuff are different. In my opinion there is nothing wrong with them and having been inside of a few they seem to be pretty well made. I do know that there are no parts available for them anymore…. I would probably stick to eaton/fuller but wouldn’t avoid buying a truck if it had a Rockwell (that works)
Rockwell just used rocks for gears, rope for gaskets and buttermilk for lubricant. Trouble shifting? Pour in some more rocks, add some more buttermilk and off you go.
