When changing fuel filter, do you reuse the diesel drained?
Discussion in 'Experienced Truckers' Advice' started by A Bug, Feb 9, 2019.
  1. A Bug
    A Bug Heavy Load Member
    896
    1,778
    Mar 15, 2014
    Sevierville TN
    Is it safe to use the fuel or is that where all the water and junk is separated to?
    I am a company driver so the price of diesel does not matter to me, it is just the inconvenience of having to dispose of the stuff. I do not want to just dump it on someone's lot.
  3. blairandgretchen
    13,376
    71,892
    Dec 9, 2011
    South west Missouri
    I put fresh fuel in filters when changing.
    Diesel fuel is a great weed suppressant.
  4. Muddydog79
    Muddydog79 Heavy Load Member
    820
    2,147
    Apr 14, 2016
    I fill new filters with transmission fluid. Heard it lubricates everything but dont know if it really helps for sure. Sure doesnt hurt, been doing it for awhile now. Never use the fuel in the old filters.
  5. TruckerPete1990
    TruckerPete1990 Road Train Member
    8,623
    5,376
    Jul 16, 2012
    Bentonville Arkansas
    It will hurt if u got a DPF filter.
    Muddydog79 Thanks this.
  6. TruckerPete1990
    8,623
    5,376
    Jul 16, 2012
    If it's a cummins isx you can put them on without filling them then turn key on for 2 mins then off then back on for 2 mins. It will prime itself.
    Midwest Trucker and Muddydog79 Thank this.
  7. Muddydog79
    820
    2,147
    Apr 14, 2016
    I dont have one, thanks for the info though.
    Mack185 Thanks this.
  8. Cam Roberts
    Cam Roberts Road Train Member
    1,621
    1,938
    May 13, 2018
    Never ever fill the secondary. Secondary goes on dry and you prime it if you have a primer or purge it. Do what ever the heck you want with the primary becuase the secondary will pick up the debris. You may not think something small will get into secondary while filling but it can and will if you do it enough times. This is just advise but the littlest thing can leave you with some downtime and an injector removal.
  9. Cam Roberts
    1,621
    1,938
    May 13, 2018
  10. stillwurkin
    stillwurkin Road Train Member
    1,756
    2,856
    Dec 2, 2017
    I have always filled both primary and secondary filters with clean fuel. Some engines will fill the filters by cranking on the starter. Some will get to much air and not want to even start. Been doing it this way since 1974, it works for me. But thats with a spin on filter, mayby not the newest, latest kind.?
    Midwest Trucker Thanks this.
  11. snowwy
    snowwy Road Train Member
    20,537
    13,274
    Jul 6, 2009
    Atf in both filters.
