When should you replace the harmonic balancer?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Ozdriver, Jan 19, 2016.
  1. Ozdriver
    Ozdriver Heavy Load Member
    767
    1,390
    Oct 16, 2015
    Australia
    Just been reading the thread on the N14 with spun bearing. There's a couple of broken cranks on there with harmonic balancers the blame.
    So, what should you be looking for? I had mine off when I resealed the front cover of my 3408 last year. It looked OK and it had been replaced about 700,000 miles ago when the engine was in-framed.
    Is there any way of telling if they need replacing? Or is it a case of replace when a certain amount of hours are up?
    Oldironfan Thanks this.
  3. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    Everybody always says every 500,000 miles it's a good idea to put a new one on.
    Or should I say , that's what is recommended.
    Oxbow and Ozdriver Thank this.
  4. supersnackbar
    19,772
    50,717
    Aug 19, 2007
    Your Town, USA
    I believe I read somewhere that the harmonic balancer manufacturers recommend between 500-750k depending on the nature of your travels. At some point they stop absorbing the torsional vibrations. And they don't call it a harmonic balancer, it is a torsional damper. There is a you-tube video from Pittsburg Power that shows one that has been cut open to see what it does.
  5. Ozdriver
    767
    1,390
    Oct 16, 2015
    Australia
    Interesting, so you can't tell by looking at them. I wish I'd replaced it when I took it off. It's no big deal replacing it. That'll be the next job. If I get one off CAT I'll try and make sure it's made in US.
    I wonder if because mine's a V8 there's less stress on the crank. It's done huge hours, but when I did a bearing roll last year there was no sign of unusual wear.
    Oxbow Thanks this.
  6. SAR
    SAR Road Train Member
    2,756
    36,654
    Nov 26, 2011
    ND
    I didn't mean to scare you ozdriver with my experience. It is hard to say why mine broke. The original balancer looked fine when it was off but didn't investigate it further. I know the cranks in certain prefix cat engines were prone to breaking from what i understand was bad casting material.
    Reason for edit: can't spell
  7. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    Someone was talking about this a year or two ago on this site, got me worried. So I went and talked to a Cummins mechanic who has 19 trucks, all Cummins power. Some N14, but most are now newer ISX.
    His N14's haul heavier weight and have more miles on them than mine. He has never seen one fail and wasn't too worried about it and told me it was nothing to worry about.
    So that's where I left it, I'll replace it it when I hit the 2mm mark in a couple years. lol
  8. AModelCat
    161,302
    There are different styles of dampers. Some are viscous and have a fluid and weight inside. Any dents/obvious damage can impair the free movement of the weight and its toast. Same with fluid leakage from the damper. Others have rubber in them. When the rubber starts to crack and fall apart its toast.
    Oxbow Thanks this.
  9. boneebone
    boneebone Road Train Member
    2,297
    2,371
    Mar 13, 2009
    Have you done any Preventative Maintenance on your N-14 like bearings etc?
    I have a N14 too and I have never touched the internals, just a had Overhead done a little over a year ago because I needed to replace a injector.
  10. Ssssnake
    Ssssnake Medium Load Member
    429
    5,608
    Oct 15, 2015
    A bad dream...
    Its not so much that a ballancer fails, but the silicone inside the balancer hardens over time. Once that happens it ceases to be able to do its job.
    Ozdriver Thanks this.
  11. Bakerman
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    Rolled in some bearings couple years ago and replaced oil pump for a low oil pressure situation. Turned out to be a loose wire on circuit board in the dash.
    Did the overhead this summer because of leaking cam follower.
    Replaced the turbo about 4 years ago along with 1 injector.
    That's all the major stuff I've done to it.
    boneebone Thanks this.
