Who works on there own trucks
Discussion in 'Ask An Owner Operator' started by Cw5110, Nov 14, 2015.
  1. Cw5110
    Cw5110 Heavy Load Member
    875
    927
    Oct 19, 2013
    Georgia
    So i have a question for most i have thought about getting a truck. Before i started driving i was in gasoline mechanics. One of the reasons why i left that side was because of the pain physically that i was always getting. Even before when i played baseball in school i ended up injuring myself. So i was wondering for O/O and L/P drivers do you work on your trucks.
    Like i stated eariler ive thought about getting my own sometime possibly next year or year after However im waiting till i hit 40k in the bank saved for maintenance expenses. Some of the people i know personally friends and family have leased trucks with a warrenty. One of them has there truck paid off and have always told me that i could get a truck now.(Which i cant do right now.) I just want too make enough money first before i start. Mainly cause i doubt ill get a new truck. But i also wont look for something that is going too keep me in the shop. Right now just still thinking what i want too do.
    Other than that i just wanted too see who works on there own truck and or if the take it too a dealer or a shop. Thanks.
  3. spyder7723
    spyder7723 Road Train Member
    15,471
    25,076
    Mar 31, 2013
    sarasota, fl
    the true business men, not the truck drivers with a truck payment, have two school of thoughts on this.
    One is new truck and trade it in at the end of the warranty cycle. For this to make any sense at all you got to be turning a lot of miles. over a hundred thousand a year. For some guys this works.
    The other is keep the truck as long as the frame is still capable of running down the road. Keep fixing it and rebuilding it yourself and don't get rid of it till the frame rails give out. Doing this, you better be willing to work on it yourself or the labor rates will make a new truck payment look like gravy.
  4. AModelCat
    160,543
    With all this emissions crap a guy better be ready to ditch it once its off warranty.
    truckon, rank and TROOPER to TRUCKER Thank this.
  5. Hurst
    Hurst Registered Member
    6,618
    12,266
    Aug 24, 2011
    Tampa, Fl
    I do as much as I can on mine. I'd say half my home time is spent on or around my truck and trailer getting them ready to head back out.
    I have an older paid for truck. I'll keep repairing it until its not profitable anymore.
    Hurst
  6. X mech
    X mech Light Load Member
    64
    22
    Nov 14, 2015
    O/O is the only way to go! Pull a reefer or flat, more revenue. Buy pre emission. Buy the factory repair manuals. Carry basic hand tools, and a 20 ton jack, and parts like governor, brake chamber, drier bypass fitting, spare tire. Service the truck your self, lube / oil. You will be able to see things needing attention. You will spend more time setting up with brokers than getting authority. If you are not mechanically inclined go new and run your ### off to pay for it. stay away from companies leasing, or rent to buy. ie Quality trucks.
    earnies2 and Cw5110 Thank this.
  7. xsetra
    xsetra Road Train Member
    5,131
    7,025
    Aug 21, 2011
    I own a 99 Freightliner with a 98 stepdeck trailer. I do most of my own maintenance. This spring I had a shop replace both trailer axles.
    This summer I replaced heads, radiator, water pump and ECM, Cummins N14 motor.
    I also replaced the transmission. I have done this in the past. This year I had the shop do it. Only $1,000.00 for labor. As I get older I find I don't want to do all my repairs, especially the ones that require me to lay on my back.
    This weekend, LOF and replace fuel supply lines. It was a nice 50 degree day outside not bad weather for the open air, gravel based repair facility. (driveway),
    Good luck with you choice.
    X mech Thanks this.
  8. daf105paccar
    6,564
    7,293
    Apr 15, 2012
    There is a 3° way to go.
    Buy new and keep it in the best possible shape,that way you know what you have.
    Buying older is a crapshoot,you never know how abused a truck is.
    And shiny doesn't mean it is in good shape.
    Also those that advocate to buy older is that they forget one thing.
    The time they spend working on them,it is a saving BUT they are working for FREE.
    Each most make his own mind up what suits him/her best for their operation.
    AND don't forget that there are a few bad years ahead.
    World economy and the USA economy are not in good shape.
    Rates are low.(several threads about it here on TTR)
    Cw5110 Thanks this.
  9. uncleal13
    uncleal13 Road Train Member
    3,797
    6,295
    Apr 9, 2009
    Humboldt, Sk
    I do as much as I can myself. Oil changes, grease, air dryer, general maintenance stuff. I have changed a fuel pump, several alternators, a power steering pump, a gasket for the top tank of a radiator.
    Just last weekend I changed the starter on my DD15. It's still under warranty, but I didn't want to loose the half day of work. They still gave me a refund for the old starter.
    Cw5110 Thanks this.
  10. wore out
    wore out Numbered Classic
    16,185
    196,164
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    I disagree that time spent working on your own equipment to save from 60 to 110 dollars an hour plus down time is working for free. How much more money in wages are you able to put in your pocket because you didn't let a shop have it. Yea I run a 1985 and a 1986. Nobody but me ever touches either
    TN_Trucker75, MJ1657, rank and 6 others Thank this.
  11. spyder7723
    15,471
    25,076
    Mar 31, 2013
    sarasota, fl
    Exactly. At today's labor rates you are looking at at least a hundred bucks an hour. The old saying a penny saved is a penny earned is as true today as then. Only exception is in today's terms it's hundreds of dollars saved is hundreds of dollars earned.
    Besides the fact it is almost always faster to just do it yourself than take it to a shop. Very few guys can just drop the truck of and go get it when it's done. Most have to sit there twiddling their thumbs while the shop works on it. plus the travel time to the shop and back.
    Father7, rank, Long FLD and 3 others Thank this.
