Why do brokers want you running do not freeze loads at 35?
Discussion in 'Refrigerated Trucking Forum' started by chalplec, Jun 24, 2022.
  1. chalplec
    chalplec Light Load Member
    81
    166
    May 6, 2022
    It's happened twice in the past week. Must pre-cool to 35 and set at 35. First place just said do not freeze on the BOL. The second said 33-80 do not freeze. First was bottled drinks second was canned drinks. Why does the broker want me to waste fuel? I set both to 70 and ran with it.
  3. kranky1
    kranky1 Road Train Member
    2,253
    8,854
    Sep 16, 2015
    Ontario, Canada
    If you’re running for broker rates a little bit of reefer fuel is the least of your worries. You could leave that unit run 24/7 and it still wouldn’t cost you as much money as the thieves do.
    Another Canadian driver and baha Thank this.
  4. wichris
    wichris Road Train Member
    4,279
    8,629
    Jan 17, 2011
    Next post will be i got a claim.
  5. kranky1
    2,253
    8,854
    Sep 16, 2015
    Ontario, Canada
    That’s a game a lot of the time too. See how fast the claim goes away when you tell them to put the claimed material back on the truck.
  6. wichris
    4,279
    8,629
    Jan 17, 2011
    If you want to pull reefer and ignore temp settings, don't cry about a claim. Or go back to a van/open deck.
  7. Six9GS
    Six9GS Road Train Member
    1,473
    3,695
    Dec 3, 2012
    Yuma, AZ
    Well, if the BOL says 35, I set it at 35. But, with a range like 33 to 80, yea, I'd set it at 70 and not worry.
    I've had numerous loads that simply say don't let cargo freeze. So, reefer stays off unless outside temp goes below 32, then I'll turn the reefer on to 40. That just what I do. Haven't had problems yet.
  8. Wasted Thyme
    7,729
    38,304
    Jan 27, 2020
    GOAT watching
    Pretty much no difference in fuel at 35 vs 70. Once it gets to the set point. Like a fridge. If you leave the door closed. It does the same work keeping it at one temperature. Plus reefer units barely use any fuel. So your risking a claim to save pennies. Not very smart.
    Another Canadian driver and alds Thank this.
  9. kranky1
    2,253
    8,854
    Sep 16, 2015
    Ontario, Canada
    My chillys were late’70’s early ‘80’s trailers, NWD30 units with Mercedes engines. I’d almost rather leave the stupid things running than try to get them started again when I needed them.
  10. DRTDEVL
    DRTDEVL Road Train Member
    1,706
    3,424
    Jan 27, 2013
    Austin, MN
    Do not freeze in June? Reefer is off.
    Do not freeze in winter? Turn reefer on, close doors, wait for boot process to complete. Set temp to current box temp (Ex. 43.2 in box, set to 43; 57.5 in box, set to 58). This uses the least amount of fuel, as it is maintaining the product at the warehouse/production facility temp.
    RefMata and buzzarddriver Thank this.
