Why won't my am radio work with an old school antenna
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by Loaderlou, Oct 10, 2015.
  1. Loaderlou
    Loaderlou Medium Load Member
    342
    131
    Feb 24, 2014
    Hi guys. I recently had my Pete roof repainted, new horns, new torpedo lights and went with an old school am fm antenna. When I tested the radio with the new antenna before installing it worked on am. Once I installed the antenna it only worked on fm. I bypassed the multiband antenna box as I did with my CB and installed the old school antenna directly to the radio. Any ideas why this would not work?
  3. Skate-Board
    Skate-Board Road Train Member
    3,801
    3,996
    Aug 9, 2014
    Merrimack, NH
    That's strange. You can use a freaking clothes hanger and AM should work.
  4. Loaderlou
    342
    131
    Feb 24, 2014
    I agree, can't understand it. It worked while I was holding it in my hand as a test. Once I drilled the hole and mounted it, dud. Can't be a ground cause I was holding it in my hand out the door. Never heard of grounding an antenna, you?
  5. baha
    baha Road Train Member
    4,137
    2,836
    Jul 25, 2013
    ga
    Try a clip to ground then to nut on back of ant. If ground on back of radio is poor am ant. will not work.
  6. Loaderlou
    342
    131
    Feb 24, 2014
    It's an OEM Peterbilt antenna that I mounted on the roof. The roof is aluminum so that makes sense. But when I tested it before mounting, all I did was hold the antenna outside the cab after I plugged it in. Didn't touch anything to ground it. I'll give it a try tomorrow. Thanks Baha
  7. BoxCarKidd
    BoxCarKidd Road Train Member
    4,469
    6,504
    Aug 26, 2014
    I do not know but what changes between holding it in your hand and mounting it on the cab. Do you remember TV rabbit ears, aluminum foil, or yelling out the window to adjust the antenna? Sorry if you missed that. Some times they only seamed to work when when someones hand was on it. "Just stay right there and the rest of us can watch TV." The coaxle cable (Braided wire on the outside of the plastic tube with the antenna wire in the middle all covered in black outside) grounds to the cab when it is bolted down. Either that changed it or it shorted out on installation. Maybe, could be possible, or just hold it out the window, at least it is for your own enjoyment. Hopefully what baha said works.
    Skate-Board Thanks this.
  8. supersnackbar
    19,106
    47,095
    Aug 19, 2007
    Your Town, USA
    I would say don't ground an am/fm antenna. My shop boom-box has an extra antenna that has a 5' wire hooked to it so you can move it around, but it's a loop and no way to ground it.
  9. beastr123
    beastr123 Road Train Member
    2,857
    23,444
    Jan 2, 2014
    Moose Jaw SK CAN
    the am antenna must be isolated from ground. If you did not get a rubber washer that isolates the exterior part of the antenna from the cab metal you can make one out of a old inner tube using a pair of scissors and cutting it at least a 1/8 " larger than the outside base. the inside mount does not have to be isolated as it is connected to the ground side of the coax cable.
    the quick test to check for isolation is to use a multimeter set on ohms or continuity and test between the inside and outside coax connectors at the radio end with it unplugged. then check the antenna itself to a ground. both checks should have NO continuity to ground!!!
  10. fargonaz
    fargonaz Road Train Member
    1,167
    4,583
    Feb 9, 2015
    Mesa, AZ
    AM antennas are usually internal to the radio, the frequency(<1MHz would be ~400' for a quarter wave) would make an external antenna very impractical. They are usually some thin wire wrapped around a ferrite bar.
  11. beastr123
    2,857
    23,444
    Jan 2, 2014
    Moose Jaw SK CAN
    only the portable am radios have only an internal antenna.
    automotive radios require an external antenna.
