Will a flat trailer tire make the air pressure on a truck's brakes slow to build up?
Discussion in 'Freightliner Forum' started by expedite_it, Oct 5, 2014.
  1. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    I find it hard to believe that you can't hear an air leak that bad. Rev it up to get it to 120, then shut it off and walk around. When your hat blows off, you're in the area.
    Skydivedavec, Grumppy and not4hire Thank this.
  3. STexan
    STexan Road Train Member
    14,963
    29,154
    Oct 3, 2011
    Longview, TX
    Well, let's see. I think the OP mentioned the unit (trailer) has a tire inflation system. I don't think there is an air hose that runs from the trailer to your home terminal's shop. So I think we can assume that the tires must get their air from the tractor/trailer air supply system. I also think we can assume that if there is a leak in the system, be it a tire or a brake chamber or hose, that this would put an additional load on the truck's air compressor/supply system. A bad leak (such as the tire has broken the bead on the rim) is going to consume all the air supply. Furthermore, it would seem that perhaps a safety valve on the TIS is bad and not shutting off the air supply to the bad tire/wheel that can never reach the prescribes pressure.
  4. loose_leafs
    loose_leafs Road Train Member
    1,294
    1,468
    Jan 3, 2014
    Old Man River, MN
    You definately have a problem. I've had trailer tires go completely flat on psi systems (tire inflators) with 1/2 inch sized hole, and a properly functioning air compressor will still put out nore than enough air to release the tractor/trailer brakes and air the bags up.
  5. loose_leafs
    1,294
    1,468
    Jan 3, 2014
    Old Man River, MN
    Most of the tire inflation systems are designed to deactivate around 95 PSI, that way a flat tire on a trailer with that system wont completely strand you. I knew I had a problem due to A. Warnining light on outside of trailer B. Secondary air gauge kept dropping like a rock going down the road, and building back up.
  6. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    What's more amazing to me is that 2 mechanics couldn't easily explain it to op
  7. expedite_it
    expedite_it Road Train Member
    1,646
    863
    Sep 8, 2012
    I am a company driver. I'm not supposed to replace flat tires myself, and I don't have the equipment to replace flat tires anyway.
  8. 25(2)+2
    18,750
    45,476
    Sep 18, 2006
    the road less travelled
    If it's on the trailer, with an inflation system, it could be a tire, or a malfunction of the system, or a leaking air bag.
    I had a leak under the tractor that I couldn't find, that was losing air rapidly, to the point of never kicking the compressor off, but it's fixed now and working right.
  9. Cranky Yankee
    Cranky Yankee Cranky old ######
    15,317
    209
    Jan 31, 2012
    Green Bay Wi
    i am a company driver too
    dont do the work myslf either but i dont drive with a flat
    i hear tell truckstops have shops that fix them
  10. MACK E-6
    48,713
    224,840
    Then you don't need to talk down to a new driver who may be trying to diagnose a leak of an air line.
    expedite_it Thanks this.
