Your knowledge is wanted
Discussion in 'Questions From New Drivers' started by Matthew7x, Oct 9, 2013.
  1. Matthew7x
    Matthew7x Bobtail Member
    5
    Sep 17, 2013
    Ok, so I have 5 questions for you experienced drivers, what is the maximum height a trailer can be? What is the maximum weight for the front axle of the truck? What is the maximum length for a combination tractor trailer? What's the maximum weight for seperated axles? What is the maximum width of the trailer?
  3. Creampie
    Creampie Light Load Member
    114
    59
    Aug 26, 2012
    Kingsport, TN
    All questions are subjective. Depending on what you're hauling, where you're hauling it, and what endorsements you have but generally
    12,000 on steers
    34,000 on dual axle drives
    34,000 on dual axle tandems
    80,000 gross weight
    Length depends on route and local laws
    Height depends on route
  4. Criminey Jade
    Criminey Jade Road Train Member
    1,609
    1,803
    Aug 16, 2013
    Not Colorado Anymore
    Are you studying for your exam?
  5. TripleSix
    130,290
    East, 13'6 tall. West 14 (most western states). Length varies, but 75 ft is safe ( not talking doubles and triples, B Trains, Rocky Mountain doubles...etc). Front axle max depends on your steer tire rating...for most, around 13000-14000 on average.
    Max axle weight depends on your wagon axle spacings and your location, but usually 17000 lbs. some allow 22000, but not on the interstates.
    Trailers width 8'6. Conestogas and other specialty trailers are allowed 9. There are certain open deck trailers that are 10-11 ft wide, but they have to buy special permits.
  6. Balakov100
    Balakov100 Road Train Member
    3,938
    2,641
    May 10, 2012
    Temple, TX
    13 ft 6 in or 14 ft.depending on state(s)
    As a general rule 14s are allowed West of MS River with some exceptions.
    This is for Box Trilers or Reefers.
  7. Passin Thru
    Passin Thru Road Train Member
    1,918
    565
    Mar 8, 2007
    VA
    Average 13ft 6in height for box trailer all 48
    CA allows 14 ft for hay loads
    A flatbed can be a drop, double drop or a flat and can be various maximum heights but the loads can only be 13ft 6in above the ground.
  8. NewNashGuy
    NewNashGuy Road Train Member
    1,616
    752
    Jul 27, 2011
    US and Canada
    Some trucks have a 20,000 limit on the steers. I didn't believe it until it was confirmed.
    blairandgretchen Thanks this.
  9. crzyjarmans
    crzyjarmans Road Train Member
    3,314
    2,441
    Jun 9, 2010
    Home
    This are just a guide to go by, steer axle can go up to 14500, tandem axles pending on state can go as high as 36000+, the 80,000 max can be broken too, if you get a permit, If you would like a list of states for more accurate weight, go to your local truck stop and look threw a truckers atlas, on single axle(non-steers) can go to 20,000
  10. blairandgretchen
    13,388
    72,037
    Dec 9, 2011
    South west Missouri
    There's a good break down at the front of your good old Rand McNally Road Atlas by state for weights and length/height etc. I see they're a little cheaper these days now they have GPS to compete with. Well worth the $25 I saw them for at the truck stop.
