Hello to everyone
I have a weird problem going on with my air tanks on my 2012 volvo vnl one of the tank some times doesn't have air when I drain tanks but guages show full air. And when I purge air with peddle braking it starts to have air in the tank. Ot sure what it is if any one have knowledge about this please help don't want to go to mechanic will be out of work for few days just for small works
Air tanks no air
Discussion in 'Ask An Owner Operator' started by Andy1982, Aug 22, 2022.
Drained water out of tanks through purge valve?
Last time changing out air dryer?Another Canadian driver Thanks this. -
Another Canadian driver and DUNE-T Thank this.
I changed air dryer a year ago and filter every 4 months one of my tanks drain tanks everyday I have three tanks getting problem in just one tank
Should be 3 tanks on the side of your truck, which one are you referring to?
I'm talking about the first one toward steering wheel side
Another Canadian driver and Andy1982 Thank this.
Another Canadian driver and Oxbow Thank this.
There is really 4 tanks in Volvo first tankbyour wet tank is split in 2 there is a valve inside that fills up tank at pressure governor cuts off so it can keep the air dryer from chuffing excessively it only gets air right about time air compressor shuts off. Behind is the wet tank than primary and sevondary tanks
Another Canadian driver, baha and 062 Thank this. -
Can't find any leaks and already changed air dryer with filter, rebuilt fan clutch, put new governor and checked the compressor, everything seems to be fine
https://youtube.com/shorts/tU9oD2CyX_o?feature=shareAnother Canadian driver Thanks this.
