Can you use ELD on a glider kit truck?
Discussion in 'ELD Forum | Questions, Answers and Reviews' started by Cobrawastaken, Apr 24, 2020.
  1. Cobrawastaken
    Cobrawastaken Medium Load Member
    481
    981
    Apr 20, 2018
    Tulsa, OK
    Now I know that glider kits have engines which are old enough to be exempt from ELD requirements, but can you still use ELDs on them if you want to?
    I personally have no problem using ELD, in fact I hate using paper logs. The company I want to lease on to requires that you use ELD. I would love to get a gilder for reliability and never have to worry about the emissions systems.
    Maybe this is a dumb question, but Google won't give me a straight answer. It would make sense to me if you can't use ELD on them since (correct me if I'm wrong) the engines are mechanical diesel engines.
    Dieselboss Thanks this.
  3. blairandgretchen
    13,376
    71,892
    Dec 9, 2011
    South west Missouri
    If it has an ECM - you can plug an ELD in.
    Lpirtle, Bean Jr. and AModelCat Thank this.
  4. Dave1837
    Dave1837 Road Train Member
    1,398
    4,342
    Nov 16, 2019
    Pennsylvania
    Yes, the company I work for has about 70 trucks and at least 75% of them are glider kits, older Series 60's. All of our trucks have ELD's with the exception of one. It's a new 579 daycab. The computer won't read when the truck is in motion. That driver just runs paper
  5. Eddiec
    Eddiec Road Train Member
    2,234
    3,429
    Feb 2, 2015
  6. ZVar
    ZVar Road Train Member
    10,911
    23,827
    Sep 10, 2010
    Flint, MI
    Depends on which engine you put in it. If it provides all the correct data then yes you can. Even if not, there is still a good chance you can install an AOBR.
    Bean Jr. Thanks this.
  7. Cobrawastaken
    481
    981
    Apr 20, 2018
    Tulsa, OK
    I would prefer AOBR if my company would let me. Really miss the days of AOBR.
    Thanks everyone else for the replies. So is there any way I can know what to look for when buying a glider if I want to run elogs?
  8. ZVar
    10,911
    23,827
    Sep 10, 2010
    Flint, MI
    I would say find the year/ model of the power train and then contact someone like @Dieselboss for which units are compatible.
    This all assumes the engine model year is a 1999 or older... Model year of 2000 and newer still require an eld, even if it is a glider.
    Dieselboss and Bean Jr. Thank this.
  9. 4noReason
    4noReason Road Train Member
    2,377
    731
    Nov 29, 2012
    what does dot use to verify its eld exempt. mine shows serial number on engine and i have a sheet from detroit with original date. but nothing on engine says year. should i keep the elog in or just paperwork needed
  10. HoneyBadger67
    2,056
    4,512
    Dec 15, 2018
    Savannah, TN
    I thought the purpose of a glider was to keep away from emissions, not ELD?
  11. longhaultransport
    longhaultransport Light Load Member
    205
    548
    Dec 25, 2009
    West Central, Florida
    You can run an electronic log without an eld.
    Check out the KeepTruckin ap.
    Lot's better than a paper log
