Differential low on fluid n noise, damaged?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by mitmaks, Nov 23, 2024.
  1. mitmaks
    mitmaks Road Train Member
    2,576
    2,088
    May 16, 2014
    Yes they're inflated
    Big Road Skateboard Thanks this.
  3. Big Road Skateboard
    6,660
    37,397
    May 2, 2021
    Not being an ###, but do you know normal clunking from abnormal clunking?
    Oxbow and mitmaks Thank this.
  4. mitmaks
    2,576
    2,088
    May 16, 2014
    Yes I regularly go under truck to check out things, leaks, seals, air leaks etc
    There's more side to side play as well about 1.5-2 inches vs 1/4-3/4 like before
  5. Big Road Skateboard
    6,660
    37,397
    May 2, 2021
    If it has to be rebuilt, just order a replacement and have the shop R&R.
    If you give a shop the opportunity to rebuild it, I'd say there's a 80% chance they eff it up.
    Just buy Weller or Spicer and call it good.
    I'd say 4k$'ish for a reputable one. Probably 5-5500$ by the time you've bought oil, labor, taxes
    Oxbow, Rideandrepair and mitmaks Thank this.
  6. Big Road Skateboard
    6,660
    37,397
    May 2, 2021
    Make a new post looking for mechanic reccomendations in that area. Maybe @Long FLD has a contact?
  7. blairandgretchen
    13,632
    74,079
    Dec 9, 2011
    South west Missouri
    I used Allstate Peterbilt there in Rapid City last year - they were reasonable.
    Big Road Skateboard and Oxbow Thank this.
  8. mitmaks
    2,576
    2,088
    May 16, 2014
    For which repair? What is reasonable if not a secret?
    Oxbow and blairandgretchen Thank this.
  9. mitmaks
    2,576
    2,088
    May 16, 2014
    If I was in WA, closer to Spokane there's inland gear who specialize in transmission n rear ends
  10. blairandgretchen
    13,632
    74,079
    Dec 9, 2011
    South west Missouri
    Oh, it was just a tank strap I had break - I just remember they were nice folks, and the hourly labor seemed lower than average to me.
    I had mine pulled and rebuilt back when I had some spare change, just because they hadn't been touched in 1 mil. Local family shop that specialized in rebuilding them went through them after my mechanic pulled and dropped off. I'm thinking it was $5-6k to do both front and rear.
    @wore out has done them on the side of the road - I know it's probably too far from @lester to recommend, and similar for @Oxbow - maybe someone will chime in that has used shops up there.
    Bad deal, - not the best time or place to be down. :(
  11. bad-luck
    bad-luck Road Train Member
    3,359
    6,212
    Nov 16, 2013
    Baltimore, Maryland
    One quart low wouldn't hurt anything. differentials hold several gallons, mine holds 5 gallons. If your differential is making noise, changing the oil in it won't make the noise go away. You will however able to see how dirty and how much metal is in the oil.
