Differential low on fluid n noise, damaged?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by mitmaks, Nov 23, 2024.
Page 5 of 5
What did you find out @mitmaks?
Oxbow and blairandgretchen Thank this. -
Differential failed. Big chunks inside pumpkin.
I'm having shop put in brand new one inOxbow, Big Road Skateboard, blairandgretchen and 1 other person Thank this. -
I dont need a driver, but if I did, I'd try to recruit you. Good job paying attention to the truck and stopping before catastrophic failure.Oxbow, krupa530, Big Road Skateboard and 3 others Thank this.
I guess It could've been worseOxbow, Deezl Smoke, Big Road Skateboard and 2 others Thank this.
It can always be worse. Glad you’re getting it sorted.Oxbow, Big Road Skateboard and Diesel Dave Thank this.
Keep your wheel bearings in mind if you have a lot of shavings. If mostly big chunks, and you have a magnet for the fine stuff, you should be okay.
Just something to noteOxbow, wore out, blairandgretchen and 2 others Thank this. -
I always tear down the hub assemblies after a come apart or a broke axle. It sux but not as bad as calling an axle surgeon.Oxbow, Big Road Skateboard and mitmaks Thank this.
Yes shop is doing exactly that. Taking bearings apart cleaning and inspecting.Oxbow, Deezl Smoke and Big Road Skateboard Thank this.
Page 5 of 5
