Faulty valve stem extensions cause flat tire
Discussion in 'Experienced Truckers' Advice' started by mitmaks, Jun 2, 2019.
  1. mitmaks
    mitmaks Road Train Member
    2,571
    2,087
    May 16, 2014
    You have to be careful if you have those extensions installed on your truck/trailer. This is 2nd time I've had this happen. Valve extension got stuck somehow and was pressing on inside of valve stem releasing air. Thankfully I carry glad hand air line so I took off extension and pumped up tire.
    KB3MMX Thanks this.
  3. starmac
    starmac Road Train Member
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    Yup, I have sold a lot of tires due them or even the equalizers that folks love to love. lol
    PE_T, adayrider, Lepton1 and 1 other person Thank this.
  4. mhyn
    mhyn Road Train Member
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    happened twice. Ones crossfire let air out .
    PE_T Thanks this.
  5. BryE
    BryE Light Load Member
    118
    345
    Feb 19, 2018
    I thought it was just me. I take a squirt bottle of soapy water now and check for leaking anytime I disturb them.
  6. mnmover
    mnmover Road Train Member
    1,237
    1,104
    Apr 5, 2009
    Lichfield MN
    The extensions also need a support pressed into the out wheel hole to support it, or the force from spinning cracks the original valve stem.
    mhyn Thanks this.
  7. mitmaks
    2,571
    2,087
    May 16, 2014
    They are not very big
  8. adayrider
    adayrider Road Train Member
    1,289
    1,732
    May 7, 2018
    What is the purpose of them?
  9. Dna Mach
    Dna Mach Road Train Member
    3,286
    3,104
    Aug 8, 2008
    Texas
    So you can check air pressure with a gauge without having to remove a cap.
    mhyn and mitmaks Thank this.
  10. buddyd157
    buddyd157 Road Train Member
    13,582
    34,896
    May 25, 2017
    under a shade tree
    i think it has to do with the metals the stems are made of and the extensions are made of. sometimes the extensions "weld" themselves to the stems. many times they get caked on dirt, and this can force them to push in the release pin just enought for a tiny leak, and in time, you have a flat tire.
    (do not forget too, that many times, many "accessory parts are made in China or some other country where they just do not use the same metals as the USA or are of course, sub-standard quality...you get what you pay for)
    we actually had the cheap plastic caps like on many cars, theis avoided such a problem
    now too, many cars these days have tire pressure monitor systems...
    it is recommended to NOT put on any extensions other than factory as the problem i mentioned DOES happen more often on our cars.
  11. bigguns
    bigguns Road Train Member
    2,846
    6,854
    Jun 13, 2013
    Omega,GA
    Anymore a lot of stuff made in the US is substandard. Or some jackoff puts the wrong part in the box.
