For long term maitenance is it better to run a reefer continious or start stop?
Discussion in 'Refrigerated Trucking Forum' started by TruckernFl, Feb 1, 2022.
  1. TruckernFl
    TruckernFl Light Load Member
    71
    55
    Jun 26, 2021
    I have a brand new 2021 Carrier reefer which I am in the process of buying. The majority of the time I use the start stop feature because the loads do not need an exact temperature they give a range. That being said I am worried the starter will go out prematurely then as if I would leave it on continous the majority of loads. Does anyone have an experience if my thoughts are correct?
  3. Frank Speak
    Frank Speak Road Train Member
    4,560
    14,015
    May 3, 2016
    If you leave it on 24/7 on every load when you could get away with it running 6-8 hours a day to maintain the temp, you’ll eventually burn enough fuel to pay for a starter.
  4. Wasted Thyme
    7,729
    38,309
    Jan 27, 2020
    GOAT watching
    Common sense. Think of your central heat and air. Do you run that all the time? Nope.
    JolliRoger Thanks this.
  5. GreenPete359
    GreenPete359 Road Train Member
    2,167
    5,128
    Oct 21, 2017
    Driving my recliner
    A starter is less than a couple hundred dollars with core charge. Fuel is expensive. Don’t trip over dollars to make dimes.
  6. wichris
    wichris Road Train Member
    4,425
    9,054
    Jan 17, 2011
    Run it the way the BOL's require and don't try to over think it.
    JolliRoger, BoostedTeg, ZVar and 2 others Thank this.
  7. Mike250rs
    Mike250rs Heavy Load Member
    881
    7,081
    Sep 24, 2019
    Raleigh, NC
    running it cont for no reason just adds to the hours on the unit.
    You will need to service it sooner and parts will wear out in a shorter time span.
    Your warranty is based on reefer engine hours as well as time.
    Also it will hurt the resale value.
    Since you are going Carrier.. ( assuming a X4 2100A/7300/7500 ) zip tie an extra alternator belt inside the cabinet. You will thank me when it chews it to shreds at 3am on a sunday in BFE. Spend $9 now or $1,200+ for the service call.
    ..and about that rear main seal, if you can get 10k hours before it goes, you did good.
    TruckernFl Thanks this.
  8. ‘Olhand
    ‘Olhand Cantankerous Crusty
    6,750
    16,653
    Jan 18, 2011
    Really depends on loads....a Carrier on a frozen load will typically get better fuel mileage on continuous...and as said before really need to just follow instructions on BOL....But weather and battery life play into it also
    Cold weather starts are hard in anything...So my general rule of thumb is...anything much under 20 degrees ambient(was below 0 this entire trip) run continuously Once at temp unit rarely works hard and doesn’t tax electrical system
    I also on longer runs on stop/start will kick it to continuos for couple hours a day....helps keep battery charged
    Just some food for thought
    Good Luck
    goga and TruckernFl Thank this.
  9. TruckernFl
    71
    55
    Jun 26, 2021
    10-4 wow I'm guessing not very many hours on it. Or more of a safety save a dollar concern
  10. TruckernFl
    71
    55
    Jun 26, 2021
    Thanks, yah I haven't factored weather in, but that will be a. Main deciding point too
    ‘Olhand Thanks this.
  11. abyliks
    abyliks Road Train Member
    3,997
    9,395
    May 2, 2010
    ludlow MA
    If it’s much over 75-80* outside I just leave them on continuous, if it’s cooler out I leave it on start and stop BUT I do swap to cont. for an hour or so a day so it charges the battery so it doesn’t kill itself cranking over and running for 90 seconds
    Unless BOL says otherwise
