Help, power to trailer in and out when connected to the truck.
Discussion in 'Questions From New Drivers' started by Ahmodaman, Oct 20, 2023.
Page 2 of 2
Back when I worked for a mega-carrier, you never knew what the next trailer would be like. I had loose junction boxes and sometimes loose gladhands. I always had a small collection of little bungee cord, which could easily be tied around the pigtail head and held to the trailer. I'd always have about a dozen gladhand rubbers, too, and a wrench in case the gladhand flanges were bent. Not much on a trailer you cant fix with just a few tools...
lester Thanks this.
I more often find the problem comes from dirty contacts. I carry a can of Caig DeOxit contact cleaner (CRC contact cleaner works, too). I spray the contacts in the socket on the trailer, and spray some inside the pigtail, too. Works every time.
gentleroger Thanks this. -
Spread the prongs…..gently
Opus and gentleroger Thank this. -
Crude Truckin' Thanks this.
If you pull same trailer all the time.
plug saver workers, I had a 6 month old trailer that would flicker lights every right turn.
Shim wouldn’t help, they’d get dim, those stopped it.
Page 2 of 2
