How often do you defrost?
Discussion in 'Refrigerated Trucking Forum' started by Frank Speak, Jun 22, 2016.
  1. Frank Speak
    Frank Speak Road Train Member
    4,489
    13,714
    May 3, 2016
    My company likes you to defrost every time you stop so that's what I do (When in Rome...).
  3. CoyoteExpress
    CoyoteExpress Medium Load Member
    367
    173
    Oct 29, 2014
    Carlingford NB Canada
    Bs ....
    After loaded and doors closed do ppw b4 start rolling
    Start the defrost
  4. Mullet_Head87
    Mullet_Head87 Medium Load Member
    451
    546
    Apr 19, 2014
    Clearwater
    Had sticker on thermo king models saying 45deg and under manual defrost every six hours but I'd do it after break and never had any problems. Some will say when it's very humid and hot do it more often but look up reefer model manual on "the online" and see what it suggests.
    Frank Speak Thanks this.
  5. Frank Speak
    4,489
    13,714
    May 3, 2016
    I should add we often have 5-7 stops. Trailer is always preloaded.
  6. STexan
    STexan Road Train Member
    14,963
    29,153
    Oct 3, 2011
    Longview, TX
    Ours are set to defrost every 6 hours, regardless (in continuo), or when it senses it may be freezing over. But I will sometimes initiate a defrost an hour or so after closing doors under certain conditions.
    HighWayMan501, KB3MMX and Frank Speak Thank this.
  7. Crazytrucker77
    Crazytrucker77 Heavy Load Member
    848
    1,047
    Nov 23, 2014
    Grants Pass, OR
    Our trailers do it automatically while running
    KB3MMX, hunted and Frank Speak Thank this.
  8. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,767
    Mar 5, 2012
    Ontario Canada
    Never. I let it do its own thing. It only goes into defrost if it's set to below 32. Then again I have my reefer mechanic take apart and clean the evaporator I think it is a few times a year. Anything in there will clog it and freeze it up much faster.
    KB3MMX and hunted Thank this.
  9. EZ Money
    EZ Money Road Train Member
    I used to do multiple stops all day in hot humid weather...I would get a code for out of range return air on the Thermo-King...well duh..I had the doors open!
    I started to hit the manual defrost after each drop and it solved that problem.
    KB3MMX, Big_D409 and Frank Speak Thank this.
  10. Frank Speak
    4,489
    13,714
    May 3, 2016
    Yeah, I usually have anywhere from 3 to 7 stops a day. I also hit manual defrost every stop.
    EZ Money Thanks this.
  11. STexan
    14,963
    29,153
    Oct 3, 2011
    Longview, TX
    Seems to me if you don't wait a while [after opening doors] for the new moisture to freeze on the coil, the immediate defrost is a waste of time. It probably takes 15-20 minutes to cycle most of the moist air through the system.
    The systems today are pretty smart and can sense when they have excess ice accumulated and will defrost when the time is right.
