Inverter help
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by Thanatos1, Dec 1, 2015.
  1. Thanatos1
    Thanatos1 Bobtail Member
    I just started driving and am trying to find out whether or not i can bring my tv and xbox along with me. My company doesn't allow inverters hooked directly to the battery so i need one the i can just plug into a 12v. Only problem is I've read that an xbox one should have at least 2200watts to safely operate and i keep seeing that inverters plugged into 12v only generate 100-150w. Also I've read posts of guys claiming that they have 400w inverters just plugged in and running heavy loads just fine. Not sure if it matters but I'm driving a 2012 international prostar
  3. supersnackbar
    19,116
    47,147
    Aug 19, 2007
    Your Town, USA
    Tv, dvd players, even smaller laptops run fine off of a plug in inverter. The xbox, I can't say because I have never used one but there should be a power rating on the thing somewhere that would give you the power needed to operate it.
  4. Rock 'n Roll Relocater
    Rock 'n Roll Relocater Medium Load Member
    481
    5,875
    Nov 16, 2015
    Near Music City
    I doubt you can run an xbox one on a cigarette lighter inverter.
  5. Balakov100
    Balakov100 Road Train Member
    3,937
    2,637
    May 10, 2012
    Temple, TX
    Assume it works still need to run TV as well prolly too much to do both.
    Should have found a better company.
    I don't know why all companies aren't outfitting all their trucks with inverters
    HalpinUout Thanks this.
  6. Chinatown
    Chinatown Road Train Member
    74,753
    170,196
    Aug 28, 2011
    Henderson, NV & Orient
    That's the right answer. Go with a company that has Apu.
  7. Rock 'n Roll Relocater
    481
    5,875
    Nov 16, 2015
    Near Music City
    Or even better....read a book. ;)
    MrsWJAA Thanks this.
  8. Thanatos1
    Also i was wondering if each 12v plug is independent or if they typically run off the same fuse
  9. snowwy
    snowwy Road Train Member
    20,545
    13,280
    Jul 6, 2009
    I highly doubt that an Xbox uses more power then a microwave or hair dryer. As much as some of you play. The power bill would be in the $1000 range.
  10. w.h.o
    w.h.o Road Train Member
    3,583
    4,094
    Jan 10, 2011
    Chicago, il
    Xbox use about 200w, cause I just goggle it for u, tv, I'll guess another 200 but pretty sure it's less. Get a 500w inverter, and there's no 500w 12v inverter in the market, only 150-200w.
  11. snowwy
    20,545
    13,280
    Jul 6, 2009
    There's 400 watt invertors that plug in to the 12v socket. Those can be found anywhere, including walmart. It's what i've been using my entire 5 years out here.
    I once had a multiple plug extension cord. Plugged tv, printer, laptop, cell phone, roku, and one of them aroma heaters. Total wattage for everything was 200 watts. Tv was 65, Laptop was also 65.
    When i came out on the road 15 years ago. 200 watts was what i had, 400 was expensive and required battery connect. That 200 powered my tv, satellite, cell phone and laptop. but i had to choose between running the satellite and charging the laptop.
