Is stalling the tractor an automatic fail on the road test?
Discussion in 'Questions From New Drivers' started by bluejet, Oct 24, 2016.
  1. bluejet
    bluejet Light Load Member
    67
    20
    Nov 8, 2014
    I passed my road test today and was very close to stalling the tractor as I downshifted to 5th gear and made a turn to get on the highway. While turning in 5th, the tractor began shaking horribly to the point where it almost shut off. I downshifted all the way from 10th with no shaking. It only started shaking when making the turn.
    Just wondering if the tractor did stall out, would it had been an auto fail?
  3. Movin On
    Movin On Light Load Member
    71
    110
    Aug 3, 2016
    Massachusetts
    It would be in my state.
    TequilaSunrise Thanks this.
  4. windsmith
    windsmith Road Train Member
    7,296
    6,031
    Sep 2, 2011
    NEPA
    If you're close to stalling in 5th on a turn, you're going way too slow. 100rpm is roughly 1mph in 5th. Close to stalling would be around 500 rpm. 5mph is a fast walk. Step it up.
  5. TruckerVinny
    TruckerVinny Medium Load Member
    375
    253
    Dec 10, 2015
    In Ohio, yes. So is lifting both hands and screwing up the break test.
  6. scottied67
    scottied67 Road Train Member
    10,818
    12,622
    Mar 14, 2010
    california norte
    Assuming it was a 10 speed, yes 5th is the recommended gear for turns. In a 9 speed, 4th would be the magic gear, and in mine after the 9 was converted to a 13 speed, 5LO was the magic turn gear.
    i just recommend applying a little throttle at the apex of the turn. Keep one eye on the left part of the turn, the other eye on the right part of the turn and another eye on the gauges to make sure you're above 1000 rpm. You don't want to lug and shudder like that. Stalling out is indeed a failure.Shows that the driver is not in control of the vehicle.
  7. bluejet
    67
    20
    Nov 8, 2014
    Thanks for the tip. Thank god it didn't stall out. It was extremely close. As close as it could get.
    Would have been a very dark day if I had failed again as this was my last chance.
    tucker Thanks this.
  8. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,130
    Mar 5, 2016
    White County, Arkansas
    Fail.
    You are too wimpy to add power. And you need a eye on at least the Tach, keep it above 1100. Anything below that you need to downshift. Some trucks will lug down but not all.
    The situation is made worse by tall fleet generic 10 speed gearing. I don't know how slow you are going, but you don't creep in a turn, add power and get in there. Let's go you will be upshifting as soon you straighten out. That is if you don't hear brakes in stereo or symphonic as several lanes you just cut off screech behind you...
    You say shake, I call it bucking. Then it will slam you back and forth causing your foot to slam back and forth on the hammer the first time you slam back, it stalls. cough cough, making you look stupid.
    Wait until your stop sign is holding you up on a 8% grade and you have to do a left off it seeing nothing but sky.
  9. AModelCat
    155,795
    I always like to be in top gear of low range for turns. I'd rather have the RPM's up higher so I can always back off the throttle and slow down a little if I need to.
    BigHossVolvo, Bob Dobalina and x1Heavy Thank this.
  10. Moose1958
    Moose1958 Road Train Member
    15,110
    33,218
    Dec 17, 2010
    Williesburg, Virignia
    If I were the examiner I would have failed you. You lugged that engine horribly. Lugging an engine is a sin in my view. In my view lugging also means you are not controlling that vehicle correctly and means you may not be ready to hold a CDL. When you lug it is the same as taking a 10 pound ball peen hammer and pounding on the internal parts of the engine. Actually I think pounding on the engine with a hammer does less damage. If you don't believe me on this ask a diesel mechanic. Some mechanics will actually start (cussing) when you bring up lugging. Inexperienced and/or lazy drivers have a bad habit of both lugging and burning clutches. I can't tell you how many times I have seen a mechanic cuss out a driver after cracking open a diesel engine and seeing damage to an engine caused by lugging and looking at/or replacing a burned clutch. Another thing that pisses off a mechanic is premature brake wear caused by riding the breaks and not using the jake properly. Stay in trucking long and you will see this.
    gentleroger Thanks this.
  11. AModelCat
    155,795
    ^^^ He's right. Some of the drivers we had driving for one of the companies I wrenched for destroyed stuff at an alarming rate. In 12 months I seen 2 clutches lock solid, numerous clutch brake failures, even a couple thrashed transmissions from improper shifting and PTO engagement. Our location only had 25 units....
    Dave_in_AZ and passingthru69 Thank this.
