Is there a....
Discussion in 'Questions From New Drivers' started by Commuter69, Sep 15, 2015.
  1. Commuter69
    Commuter69 Road Train Member
    1,137
    632
    Jul 2, 2014
    Good list of tools/supplies a new company driver should carry on board to deal with easy minor issues?
    All I can think of is:
    *containers of oil, coolant, and washer fluid.
    *cleaning supplies (for cab interior: spray bottle of washer fluid or window cleaner, paper towels, cleaning wipes, rags).
    * broom that can be disassembled(brush from handle) and dust pan for sweeping out trailer.
    *screwdriver/wrench/locking pliers/multi tool/hammer(if it's broke, hit it till it's not).
    *fuses, light bulbs, glad hand gaskets, misc nuts/bolts.
    * flashlight
    Any thoughts about chem lights in addition to reflective triangles?
  3. Cottonmouth85
    Cottonmouth85 Bad Influence
    2,637
    8,701
    May 3, 2012
    Floresville, Tx
    Save the glow sticks for raves....
    Add WD-40, super glue, duct tape and a few bungee straps to your list.
    Consider building up a better tool box than what you can find at wal mart.
    A cheap mulit meter and test light for diagnosing electrical problems.
    I use one of those mini bottles of dish soap and run a bead across the squeegee to clean the guts off the windshield and for the interior that generic citrus scented furniture polish is better than armor all.
    S M D Thanks this.
  4. Smooth_Operator
    Smooth_Operator Light Load Member
    203
    176
    Jun 29, 2015
    And cash.
    Cottonmouth85 Thanks this.
  5. Cottonmouth85
    2,637
    8,701
    May 3, 2012
    Floresville, Tx
    Yeah... cash is a must have. At least $300 I think. And a case of bottled water.
    And I keep my open fluid containers in a plastic milk jug crate in the side box. Nothing worse than mopping up spilled oil.... speaking of, a few shop rags won't hurt either.
    An air line to air up tires is also a must have.
  6. w.h.o
    w.h.o Road Train Member
    3,583
    4,094
    Jan 10, 2011
    Chicago, il
  7. IronWeasel80
    IronWeasel80 Medium Load Member
    387
    375
    Sep 4, 2015
    Belen, NM
    • Fire extinguisher - This should already be in the tractor, but it doesn't hurt to have more than one of at least 10lb ABC type.
    • Crescent Adjustable Pry bar - I have one of these in the 16" model (also comes in 24") and it's incredibly handy to have around. It's a hammer / pry bar / nail puller and it has come in handy numerous times. Push that little "button" on the head and that portion slides up and down, it's not fixed like the image shows. http://www.crescenttool.com/crescent-db16-16-adjustable-pry-bar-nail-puller.html [​IMG]
    • At least 50' coiled 1/4" line with appropriate air chuck.
    • High quality tire gauge.
    • Tire thumper of some sort (pry bar above, small fire bat, etc.) Just make sure to not thump your steer tires.
    • I highly recommend LED lights for everything. You can buy little 3 LED lamps that clip onto your hat or even a small LED light that has a strap and you can wear it on your head. Frees up both your hands.
    • Leather gloves and / or Mechanix (brand name) gloves and also some chemical resistant gloves.
    • Baby / sanitary wipes for washing your hands when you don't have appropriate facilities nearby.
    • Bungee cords and tape have already been mentioned, but have a small roll of rope and / or twine. Never know when you may need to tie something to secure it of get it out of the way of something else.
    • Small load straps - see previous reason.
    The other posts have also given some great suggestions and hopefully others will chime in as well.
    Josh_B Thanks this.
  8. Pintlehook
    Pintlehook Road Train Member
    1,244
    1,923
    May 2, 2013
    Linesman pliers and possibly a pair of bolt cutters should be added to the already good list.
  9. HorseShoe
    HorseShoe Road Train Member
    1,494
    2,779
    Jun 29, 2015
  10. RustyBolt
    RustyBolt Road Train Member
    2,073
    3,333
    Feb 21, 2015
    Bement, IL
    ZIP !!!
    TIES !!!!
    Assorted sizes. And electrical tape.
    Josh_B Thanks this.
  11. blairandgretchen
    13,430
    72,404
    Dec 9, 2011
    South west Missouri
    Big mule wipes instead of baby wipes - Fleet Pride.
    Vice Grips for clamping off bad brake chamber.
    Nameless One Thanks this.
