Need help learning alley dock San Diego, CA
Discussion in 'Trucking Schools and CDL Training Forum' started by iBossBella, Nov 4, 2019.
  1. iBossBella
    iBossBella Bobtail Member
    Nov 4, 2019
    California SoCal
    I have my class A permit with all the endorsements. I have taken the skills test twice and keep failing the alley dock portion. I can straight back, off set, and parallel park. And I can also drive just fine. Please I need someone that can teach me what to look for and how to alley dock truck. I really need to pass cdl test to get a job and support family. The school I currently attend isn’t giving enough behind the wheel training time and the time we did get was split with several people. When replying please let me know your schedule and charge to train. Thank you.
  3. truckdriver31
    6,998
    8,363
    Sep 18, 2013
    whats alley docking. i just put it where i need to.
  4. Chinatown
    Chinatown Road Train Member
    77,852
    184,934
    Aug 28, 2011
    Henderson, NV & Orient
    Robertson's Ready Mix will probably hire you right now with the cdl-a permit.
    They have a facility in San Diego.
    Robertson's has a program to help cdl-a drivers get the hard copy cdl-a.
    iBossBella and truckdriver31 Thank this.
  5. iBossBella
    Nov 4, 2019
    California SoCal
    Thank you so much. I’ll def give them a ring in the morning.
    Chinatown Thanks this.
  6. Chinatown
    77,852
    184,934
    Aug 28, 2011
    Roberton's Ready Mix - El Cajon, CA
    Local Commercial Drivers
    • Not Licensed? No Problem - We will Train! No experience necessary, PAID TRAINING, full benefits, holiday pay & 401K.
    • Must be 23 years of age & Ready to work days or nights
    • All applications MUST be submitted with an K4 ( DMV printout form) that is current within 30 days. (ONLINE VERSION NOT ACCEPTED)
    Please visit us at rrmca.com to find the location nearest to you.
    iBossBella Thanks this.
  7. Ffx95
    Ffx95 Road Train Member
    1,370
    2,635
    May 18, 2017
    Alley docking is when you do a full jackknife right? Can’t think of many times you should use it too many blind spots and if you do it wrong you end up needing more space than just backing at a 45 degree angle .
    truckdriver31 Thanks this.
  8. Redbeard007
    Redbeard007 Light Load Member
    82
    40
    Dec 31, 2016
    The alley dock is the 90 degree back if i remember right. Start at the cone, hard right until ur back trailer tires stop moving then hard left until they start moving then as soon as they start moving put ur wheels straight for a few seconds and then pull up hard right to take half the angle out of the trailer then start walking then trailer in. Thats how i was taught
  9. Midlife Trucker
    Midlife Trucker Light Load Member
    281
    288
    Dec 3, 2011
    Shady Dale, GA
    Here’s my method. Set up is crucial. I want my DOT bumper to be 12’ out from the corner cone and 10’ past it. Keep in mind, each truck turns differently, so you will practice and adjust this for what you are driving. My trailer wheels are at the 41’ mark.
    I start the maneuver by turning my wheel fully to the right. I want the trailer to go left, so I turn right. I fully jackknife my tractor. Our trailers have a reflector, if yours doesn’t consider a stick on one. I stop when fully jackknifed. Now, I turn my when fully to the left to chase the turn, I watch my trailer wheels. I do not want them to roll toward the back. I want my DOT bumper to be at the entry of the box but 2’ - 3’ from the driver’s side cone. Since I am jackknifed there is no way, with this set up my trailer will hit the right side cones.
    I keep chasing the turn to enter the box. Straightening the truck with my wagon. If I need to, I pull up, turning the fully to the right, then back to the left. Then it’s s straight line back.
    Keep something in mind, I’m no expert. I just passed my CDL. I’ve got less than a hundred alley docks under my belt. I posted this because I felt the steps that I use might help you if I gave them to you in detail.
    A previous poster is right, a 45° back is a better alternative to the 90° but the test requires that maneuver. After the initial jackknife, you could pull up straight turning the back into a 45°.
