P&D Rookie Advice (Post yours)
Discussion in 'LTL and Local Delivery Trucking Forum' started by road_runner, Oct 15, 2016.
  1. road_runner
    road_runner Road Train Member
    3,492
    8,947
    Mar 26, 2012
    Montucky
    So where to start. I've been doing P&D for three years now. Had about 9 years of previous driving experience. Most was all linehaul of some sort. Turns out P&D lets you be home during the daytime, so I switched to it. I am not gonna talk to much about that since I have enough threads going on that subject. What I will talk about is some stuff I wish I would have known when I first started.
    For those that don't know what P&D is, it stands for "Pickup and Delivery". In the world of LTL, you are the CDL equivalent of the UPS or FedEx Ground guy going door to door delivering stuff. Difference is, you will drive a tractor trailer, you will deliver freight that is almost always more than 50 lbs, and you will have to think on your feet on how to get it off your trailer and into the custody of your customer. Speaking of customers, most of your freight will be B2B while probably less than 10% will be B2C. You will usually pick-up or deliver a combined total of 15-28 bills on an average day. Our parcel counterparts run over 150 stops on average. Even at less than 20% of the workload, your day will probably still be as hectic and stressful due to the nature of the freight.
    One thing I had going for me was I knew how to back. Jacknife backing a 9 ft wide liftgate to line up with a 10 ft wide double door? - No problem. Blindside it off of a 4 lane busy roadway while blocking two lanes? - Piece of cake. If you are good at backing, you will do OK with this job. If you are an expert confident backer, you will do really well. Anything less than that, you will have a crap time doing P&D until you get your backing skills down. Keep that in mind.
    So here is some stuff that I wish I knew before hand:
    1. Use Google maps.
    You will probably burn a bunch of data on your phone if you are not familiar with the area. But running a quick sat image can provide vital info that can prepare you on how to get in... and more importantly, how to get back out. You will also see how things are situated in terms of space. Using cars, trees, fences as reference points will give you an idea if this delivery or pickup is manageable with a 48 ft trailer... or only a pup. (On a side note, my carrier Verizon offers a 17% discount for working for YRC. Check with your carrier to see if your company qualifies for a employer discount).
    2. Call ahead.
    This should be #1 but many people prepare themselves for a new delivery just by looking up the business/home on maps. Seriously though.. Check your Delivery Receipt (DR) for a phone number. Your best source is to call up your coworkers and ask them for advice... but sometimes they are too busy with their own deliveries and pickups, so you have to rely on your customers. Nothing wrong with a quick mobile shoutout: "Hey, this is Jimmy from Yellow Freight, I got this engine for your address, can you please give me more information so I can complete my delivery?".
    You can then follow up with these basic questions:
    A. Where exactly are you guys located? I've never been there before/my gps is throwing your address into a empty field.
    B. Where is your loading dock located? What is the easiest way in and out? Or... how do other carriers usually deliver/pick up your freight?
    C. GPS shows a tight turn... can I get in with a XX ft trailer? If not, would you be willing to meet closeby and have your forklift guy shuttle it a extra few feet?
    D. Will you be available to receive it? ... this is kinda a big deal. Some places will close for lunch... or just shut down early. Residentials you gotta call regardless for this question. I once backed down a 300 yard driveway with nobody home.
    Customers will almost always be happy to hear from you so they can get their freight faster. Don't be shy to use your phone
    3. Get Out And Look
    Seriously, don't get yourself in a bind. I've been doing this job for thirteen years. Today I got out four times due to questionable space while backing in between cars. Trust me... having bigger balls to take on bigger risks when backing doesn't make you a better driver. You are just a bigger idiot when you back into something cause you thought you were a super trucker. Put down your pride, all the professionals do it.
    4. The easy way in.
    I once spent 15 minutes backing 20 yards. The entry way was so tight and the curves so complex, it was time costly. Once I got in, I was told that most carriers stop on the side of the road. Seriously... two words of advice. Sometimes the easiest way in is to stay where you are (outside the gate). The other, before you try your super trucker skillz... get out and look... then ask your shipper/receiver where they want you. If other carriers can get in, so can you. This goes back to having a solid foundation on backing skills.
    5. Don't be a doormat
    When picking up or dropping off a shipment, keep in mind what part of the process each person plays. While some deliveries are more time consuming than others, there are customers that may expect you to do more than you are required to do.
    Inside deliveries means you bring it inside. Sometimes with hotels, you break down a pallet and hand truck it into their laundry room. If you are running something similar for a retail store, you are not required or expected to sort and segregate their freight. Quick example is a friend of mine who had to deliver a pallet of shoes. The manager asked him to break down the pallet and sort all shoes based on style and size onto their product shelf. NOPE. Not your responsibility. If you expect to stay longer than you have to, call up your dispatcher and keep them in the loop.
    Same thing with pickups. When you get to a pickup, their freight needs to be boxed up, and in most cases banded to a pallet. then shrink wrapped with a proper shipping label. The Bill of Lading (BoL) has to be completed. The To, From, Product Description, Weight, Class, and Signature block have to filled out.
    I've had customers ask me to shrink wrap their freight. Just say NO. Anything you accept that is not par with shipping requirements falls back on you. I occasionally will make a copy of a BoL and use that as a shipping label for the customer when I get back to the barn. Do not pick up anything without a BoL... especially Hazmat.
    6. Be honest.
    If you see something wrong or damaged with the freight, don't just pawn it off. Let your customer know the issue before it gets off your trailer. For one, it is the right thing to do. Second, it may save you time in case they want to refuse it. And finally, it builds trust between you and the person receiving the freight. Cause the next time you are in a hurry and the customer asks you if everything looks alright, he will take your word for it.
    7. Empathy
    No carrier is perfect and freight will get damaged or downright destroyed. I once delivered what was supposed to be a 2K lbs pallet of tiles... except it was three pieces of tile and some shrink wrap on a pallet. The consignee was PISSED. There are instances of drivers getting fired cause they lost their cool and got into a shouting match with a customer where neither one had control of the actual freight.
    "Sir/ma'am, I am sorry about your freight. I totally agree, this is completely unacceptable. I know you need this freight to complete your job, and had I been in your position, I would be upset too. Just know I had nothing to do with how your freight showed up, but I am required to make a delivery attempt regardless" You will be surprised how quickly that paragraph will defuse situations that appear unmanageable. Be sincere and genuine. If you treat their freight like it was yours, it is easy to emphasize with your customers
    8. Be friendly
    I have customers that see me back in, and view me as the grim reaper. I am here to provide you with a trailer load of work ...on a Friday afternoon when you just want to get home. Trust me. People may not be thrilled to see you pull in. But being social helps break down this work barrier. Just asking how their day is or what their plans for the weekend is can help the delivery go by smoother. Don't be that guy that pulls into a stop where employees have to draw straws to deal with you. We actually lost freight over drivers that were jackholes (they eventually got fired though).
    Thanks for reading. Please add more advice if you have any.
    Reason for edit: Misspelled "Bill of Lading"...
  3. Big Don
    Big Don "Old Fart"
    17,996
    35,643
    Sep 8, 2007
    Utah's DIXIE!
    This is so basic that it probably doesn't need to be mentioned, but that has never stopped me yet...:D
    When doing a pickup LOOK at what you are picking up. I've seen drivers pick up obviously damaged freight, without noting the damage on their bills. Same thing with shortages.
    If you have a question as to whether or not you should pick it up, get on the phone with your supervisor. You can't get into much trouble by kicking the problem upstairs. That's why they make the big bucks.
    Another basic thing. WATCH YOUR OVERHEAD! Sooner or later, you will run into a driveway that has a utility line that is too low. Maybe it was built that way, or maybe it is sagging do to a damaged pole. Cable TV is notorious for having lines that are below legal limits.
    GoBlue487, misterG, MACK E-6 and 5 others Thank this.
  4. Big Don
    Big Don "Old Fart"
    17,996
    35,643
    Sep 8, 2007
    Utah's DIXIE!
    One more thing, if you have the ability, take pictures of any damaged freight that is put on your truck, whether you are at a customer pickup, or being loaded at the dock for you to deliver. Try to frame the pictures to show WHERE THE FREIGHT IS. This keeps your backside covered, should someone accuse you of damaging it.
  5. Sho Nuff
    Sho Nuff Road Train Member
    1,175
    1,401
    Apr 9, 2015
    When I did P&D, I would say the hardest part was time management. Trying to figure out how to route your stops and pickups if you didn't have a bidded run. A good GPS or Google maps is definitely mandatory since no directions are given. I always asked anouther driver if they were familiar with the area and to help route and setup the loads in the trailer. And since my start time was around 10:30 am, usually the first stop I went to wound up on lunch break, so I usually took my 30 while I'm waiting for them to come back from lunch, or hit anouther stop that wasn't on lunch break and come back later.
    Driving to me wasn't the hardest part. Dealing with the pressure to make all your deliveries and pickups, with dispatch constantly changing things up, was part that bothered me. So my rookie advice is to learn how to deal with pressure, because you'll definitely be stressed out trying to make all your pickups and deliveries before everything closes.
  6. RoadRooster
    RoadRooster Road Train Member
    4,121
    6,709
    May 10, 2015
    Fort Myers, Florida
    lift with your back not your legs that's why they give you those back supports...they don't give you any knee support to do they
    alds Thanks this.
  7. Mike2633
    Mike2633 Road Train Member
    6,461
    25,989
    Jun 14, 2013
    At Home on The West Side
    Sho Nuff is right my old Friday I had several stops that had to be off by 10:00am that way I could get to another place before 11:00am. You really have to hustle sometimes.
    DRAGON64 and Sho Nuff Thank this.
  8. JReding
    JReding Road Train Member
    1,955
    3,504
    Sep 8, 2014
    Puyallup, WA
    All excellent advice, and great topic for P&D rookies.I know I'll be echoing some of it, but only to emphasize the value or importance of it.
    As @road_runner has already touched on, don't underestimate the value of empathizing with the customer. I had one advantage over my coworkers in that area, and that was that before I started driving, I spent 9 years in retail, mostly doing customer service. I learned to listen to the customer, and when the customer sees that you're actually interested and paying attention to their comments and concerns, their trust level in you will go much higher. Work at being knowledgeable enough of your company's policies to be able to offer solutions to a problem. And if you don't have an answer, tell the customer, "I don't know the answer to that one, but let me talk to my [supervisor/salesman/manager], and I'll get back to you when I have an answer." When they see you coming in, they will be put at ease, and your delivery/pickup will go smoother for both of you.
    I'm assuming most if not all LTL carriers start the new guy on what we used to call the "various" board, but eventually you will be able to bid on a route. When you do, though, be willing to take whatever route your dispatcher may need covered; he may have had someone call out sick, or they're on vacation, and the dispatcher needs to plug a qualified driver into that run. I had the same route for about 13 of my 18 years with my previous company, but my dispatcher was confident in asking me to cover literally any route we did. I could find my way to upwards of 300+ of our customers, knew their hours and requirements, even when they took lunch, if they happened to shut down for it, all off the top of my head. Believe it or not, our terminal covered an area of about 11,000 square miles, with about 70 drivers.
    LTL can be hectic, but never get in so much of a hurry that you sacrifice safety for convenience or speed. It's still your license on the line, no one else's. Always get out and look. And proper planning of your day will help you make the best use of your time, so that you don't have to worry about pressing yourself too hard, too fast.
  9. Mike2633
    6,461
    25,989
    Jun 14, 2013
    Make time up on the dock not on the road.
    Bob Dobalina, Sho Nuff and JReding Thank this.
  10. Buckeye91
    Buckeye91 Road Train Member
    1,095
    677
    Sep 26, 2011
    Midwest, USA
    Awesome thread! This is much appreciated, I've been in the LTL game for over a month now and have been picking up on small things here and there. So I will definitely be following this thread. I've been following pretty much all of you for the last 2 years as I debated on switching to LTL, so I know you guys have experience! I also keep my ears open, always listen to advice from fellow drivers.
    P&D is pretty hectic. But it's a good hectic. Luckily I drove in Chicago for a couple years so city driving is nothing to me, in fact that's why I wanted to do P&D. To bounce around the city all day.
    So far I've only ran into someone closed at lunch. I just went to my next stop a few blocks away and then returned, minimum time lost.
    The thing that I've had to worry about is my half hour break. Normally I start later in the day so this doesn't apply, but on the few days where they called me in around 8-9. My 8 hour clock is ending just when everyone seems to be closing. So far I haven't missed any pickups, but it's came within minutes.
    I definitely do not have any regrets coming to LTL. My company is awesome as well, so that makes it even better. I can pretty much say I found a home!
  11. MACK E-6
    48,217
    220,426
    Nice write up, @road_runner. Well done.
    To add, engines can be the death of a driver's back if he's not careful, especially V-8's. Half the time the crates won't accept a pallet jack, and at usually upwards of 400 lbs a pop one can forget trying to move one of these with a hand truck. You have to get your dock crew to set it on a standard size pallet for you.
    Safes can be another problem, especially at houses. With those, before you unload it is often prudent to ask "before I unload this thing how do 'you' intend to get it to its final resting place".
    That way, if they refuse it because it isn't your responsibility to take it in the house, and regardless of whatever "they" may have told the consignee whomever "they" happens to be you can rest assured it's most certainly NOT, then you won't have to deal with trying to get it back on the truck.
