Rollover Risk for these 2 load scenarios.
Discussion in 'Ask An Owner Operator' started by GatrLuvr, Jan 8, 2024.
  1. GatrLuvr
    GatrLuvr Bobtail Member
    Jan 8, 2024
    Considering that both loads are properly balanced, loaded and braced in the correct way without any risk of shifting while negotiating corners, which trailer would be more likely to be involved in a rollover incident as a result of going too fast on the highway or, in other words, which would actually necessitate going slower around turns?
    A: A very heavy but low center of gravity load like steel girders directly on the floor.
    B: A relatively light but full load (26-30 pallets) stacked almost to the roof.
    I wasn't able to find a post regarding this or information through searching online, maybe this seems really obvious to some people but I'm honestly not sure, It seems to me it could go one way or the other (pun not intended).
  3. blairandgretchen
    13,932
    76,571
    Dec 9, 2011
    South west Missouri
    No physics professors going to take this one . . .?
  4. Judge
    92,024
    A won’t go anywhere unless not tied down properly.
    B wo t be a light load, pallets are heavy stacked up and pull heavy on flatbed.
    But it’s top heavy, it’ll lean and to much lean is not good..
    curve/ramp limits are for cars.
    Go a few mph below and easy, not run up and turn at last minute on any loads.
  5. 77fib77
    77fib77 Road Train Member
    11,654
    76,868
    Jul 7, 2010
    St Louis
    In cyro they wanted us 10 to 15 under the curve suggested speed. A cyro trailer is 400k. Very spendy.
    It's better to be safe. You only need to be wrong once.
    To your question if the loads wont move, secured properly. The true center of gravity would determine the which one is safer.
    m16ty and blairandgretchen Thank this.
  6. REO6205
    REO6205 Road Train Member
    13,168
    60,500
    Feb 15, 2014
    California.
    Cyro?
    blairandgretchen Thanks this.
  7. 77fib77
    11,654
    76,868
    Jul 7, 2010
    St Louis
    Liquid oxygen, nitrogen.
  8. blairandgretchen
    13,932
    76,571
    Dec 9, 2011
    South west Missouri
    CRYO - Cryogenics - you darned grammar/spell check/dyslexic nazi ! :)
  9. Cat sdp
    Cat sdp . .
    21,304
    76,204
    Apr 8, 2012
    Orion's Belt
    I bailed out of physics, but my guess would be the lighter load if in Montana
  10. Tug Toy
    Tug Toy Road Train Member
    7,067
    73,946
    Jul 4, 2015
    Corn field
    I like it heavy and low but, haul high and heavy. IMG_2445.jpeg but find it really don’t mater how it’s loaded but more about how it’s driven IMG_1159.jpeg
  11. Ridgeline
    22,721
    123,347
    Both, if you want an explination, then learn how the actual center of gravity is determined.
