I was pulled in Maryland today overweight gross. 6 or 8 hundred pounds. Wasn't until after the inspection and officer left I said to myself wonder of he gave credit for apu exemption. Went over and inquired while he sat in vehicle preparing ticket and guess what he totally didn't and said if I hadn't brought it to his attention I was screwed. So he let me off with a warning for discharged fired extinguisher that accidentally happened last week when I was placing it in side box. Guess I just get hit on csa. How many points anyone know?
Warning ticket result of Apu exempt
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by CleverNDGuy, Feb 17, 2017.
393.95 is 2 points. First year multiplier of 3, 2nd year 2, and 3rd year 1.
CleverNDGuy Thanks this. -
That APU exemption is only for the weight of the APU, which is about 400-500 lbs. Its not accepted in every state, and in some states it's at the whim of the DOT. You got very lucky with that fire extinguisher warning.
CleverNDGuy and Tb0n3 Thank this. -
Tb0n3 Thanks this.
§393.95 Emergency equipment on all power units.
(a) Fire extinguishers—
(4) Condition, location, and mounting. The fire extinguisher(s) must be filled and located so that it is readily accessible for use. The extinguisher(s) must be securely mounted to prevent sliding, rolling, or vertical movement relative to the motor vehicle.CleverNDGuy Thanks this. -
Bean Jr. Thanks this.
I once asked about the APU exemption at a New Mexico scalehouse, and the officer told me that federal regs allow a CMV to exceed 80k by the weight of the APU or 400 lbs, whichever is less.
Of course, having a good attitude when talking to LEO can always tilt the odds in your favor, and vice versa.driverdriver and CleverNDGuy Thank this. -
Overweight carries no CSA points to the carrier and no PSP reporting to the driver. You just talked yourself into a warning that does carry those points and reporting.
