When choosing a company how important is it to consider the FMCSA scores?
Discussion in 'Questions From New Drivers' started by jungledrums, Jan 6, 2014.
  1. jungledrums
    jungledrums Heavy Load Member
    776
    828
    Oct 28, 2013
    Tennessee
    I'm not sure if the FMCSA scores reflect negligent drivers or company. One company I am considering going to has really bad scores for Unsafe driving 81.3%, HOS compliance 64.7%, vehicle maintenance 68.6%, drug/alcohol 46.9%
    Are the drivers to blame, or should I run from this company because they have serious issues within?
  3. double yellow
    5,946
    10,066
    Aug 28, 2011
    State of Jefferson
    Run away from that company.
    High numbers across mulitple categories suggest systematic problems throughout the company. It is less likely that you can work there and maintain a clean csa -- which will make it harder to move on to better companies. It will also mean more attention from the law enforcement.
    On a very small company, it could all be from 1 incident from 1 driver (e.g. driver with drugs in system is running illegal logs, speeding, on bald tires that company would gladly have replaced if they had been told), but usually it'll be an indication of an outlaw outfit not adjusting to the times...
    A single high category is less of a concern. High drug/alcohol scores, for example, aren't something that would concern me (one or two bad apples can really skew the score over a short term). Likewise unsafe driving wouldn't stop me from picking a company, though it may indicate pressure to run harder than legal (especially if combined with HOS issues).
    Vehicle maintenaince does concern me -- especially if you will be doing a lot of drop and.hooks... It does seem to correlate with how well the equipment is kept. If a small company had a high vehicle maintenance score but I would be driving the same equipment all the time, I'd only be concerned with whether they are reluctant to pay to fix issues. Again one or two lazy drivers can really screw up a small company's score.
    jungledrums and tow614 Thank this.
  4. 77smartin
    77smartin Road Train Member
    2,183
    3,023
    Apr 3, 2011
    I dunno.
    Look at the violations...that tells the story.
    jungledrums and double yellow Thank this.
  5. jungledrums
    776
    828
    Oct 28, 2013
    Tennessee
    This company has about 800 trucks and everything I can read about them on here says they are one of the best companies out there. Those terrible scores are surprising.
  6. bad-luck
    bad-luck Road Train Member
    3,289
    6,052
    Nov 16, 2013
    Baltimore, Maryland
    What this company has done is made themselves a target for dot. Both the drivers are to blame as well as the company for not addressing it and letting it get that bad in the first place. I would steer clear unless you want to be on a first name basis with dot.
    jungledrums Thanks this.
  7. Cranky Yankee
    Cranky Yankee Cranky old ######
    15,317
    209
    Jan 31, 2012
    Green Bay Wi
    you might as well name the company
    others here will have first hand exp
  8. jungledrums
    776
    828
    Oct 28, 2013
    Tennessee
  9. jungledrums
    776
    828
    Oct 28, 2013
    Tennessee
    As a newbie, that's the last thing I need!:biggrin_2556:
  10. blairandgretchen
    13,376
    71,891
    Dec 9, 2011
    South west Missouri
    I say yes - it's a close reflection.
    Having witnessed the driving habits of said company, it doesn't surprise me.
    It's an interesting debate - we've all gotten BS tickets . . .
  11. pattyj
    pattyj Road Train Member
    22,474
    20,137
    Jul 19, 2008
    Sioux City,ia
    Run far away from this company.Scores tell a lot and relects you and your cdl.Not worth it.Drivers are partly to blame because they knowing drive unsafe and don't say anything.In this industry money is first and safety is when they find timeThose are hgh percentages you gave.With bad scores like this,why are you considering them?
    Father Luke Thanks this.
