Why isn't everyone using the bunk heaters by now?
Discussion in 'Questions From New Drivers' started by Diantane, Feb 24, 2016.
  1. Diantane
    Diantane Light Load Member
    200
    575
    Nov 13, 2010
    Alderson, WV
    Some nights I come into the rest or truck stop and everything is so quiet (no engine is running). Then a truck comes in and runs his engine all night. If bunk heaters were expensive I could see this, but they aren't and they are very cheap to run (a dollar's worth of fuel instead of twenty).
    Some drivers tell me that they prefer the high heat from the engine. I tell them that the most heat that comes from the cab is 90 degrees. The sleeper with its larger heater core is 120. But the heat from an Espar bunk heater is a whopping 150 degrees! That's enough to keep anyone toasty all night.
  3. Lepton1
    Lepton1 Road Train Member
    12,647
    25,588
    Nov 23, 2012
    Yukon, OK
    I'm totally in agreement on this one. The best nights rest for me is in the middle of nowhere without the engine running. Since I enjoy sleeping in the cold and have plenty of warm blankets and comforters I leave the bunk heater turned off and the window by my head cracked open, then set my alarm to turn on the bunk heater about 10 minutes before crawling out of my cacoon.
    I'll idle if temperatures are projected to drop below 20°F to keep the fuel from gelling or if it starts getting ungodly hot.
    alds and White_Knuckle_Newbie Thank this.
  4. Moose1958
    Moose1958 Road Train Member
    15,169
    33,411
    Dec 17, 2010
    Williesburg, Virignia
    I'm with you in my heart, but with that said some drivers don't have APUs or bunk heaters. Their companies just don't put them in. Maybe in another few years this will change.
    Lepton1 Thanks this.
  5. Redtwin
    Redtwin Road Train Member
    5,487
    7,608
    Aug 17, 2012
    PBC, FL
    May be running a fridge and other electronics off the inverter and have to keep engine running so the batteries don't go flat.
  6. Big Don
    Big Don "Old Fart"
    17,996
    35,643
    Sep 8, 2007
    Utah's DIXIE!
    Sheesh, the things people whine about! If you're gonna drive a truck, then grow up and learn to accept things as they are.
    Frankly, I miss the old days when nobody ever shut off their truck for any reason.
  7. w.h.o
    w.h.o Road Train Member
    3,583
    4,094
    Jan 10, 2011
    Chicago, il
    Not everybody has a bunk heater or it doesn't work.
    Joetro Thanks this.
  8. kidsdad
    kidsdad Medium Load Member
    327
    298
    Nov 11, 2010
    central illinois
    I sleep better when my engine is running, I like the sound and the gentle rocking.
    austinmike and Big Don Thank this.
  9. mitmaks
    mitmaks Road Train Member
    2,560
    2,075
    May 16, 2014
    I use my bunk heater-Espar
  10. duckdiver
    duckdiver Road Train Member
    1,057
    876
    Mar 28, 2012
    Surf city
    People who run their trucks in a quiet truck stop deserve what they get when they park next to me.
  11. w.h.o
    3,583
    4,094
    Jan 10, 2011
    Chicago, il
    and what's that?
    alds, flatbedder and Joetro Thank this.
