Won’t start after oil change
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Gavinstone, Feb 25, 2018.
  1. Gavinstone
    Gavinstone Bobtail Member
    So I drained the oil and took off the oil filter and put on a new one. Started truck after putting fresh oil in it and the truck blew all the oil out of the filter and shut off. Figured out the filter came without an o ring so it was replaced with a new one it is not leaking has full new oil in it and the truck won’t start. I have no clue what’s going on
  3. V c2c
    V c2c Light Load Member
    218
    176
    Aug 16, 2016
    Waco Texas
    Did you change fuel filters as well by chance?
    blairandgretchen Thanks this.
  4. Goodysnap
    Goodysnap Road Train Member
    3,502
    8,384
    Jul 12, 2017
    Ouch..... sounds like that was an expensive oil change.
    You could start by telling us what your working on?
    If you don't know what your doing then take it to someone that does.
    Hulld, QUALITYTRUCK and Heavyd Thank this.
  5. Heavyd
    Heavyd Road Train Member
    7,626
    6,027
    Feb 4, 2009
    When you have a problem, you need to tell us what year, make, and model of truck and engine you are working on. We aren't mind readers. Some engines run the injectors by oil pressure, so no oil, no injection and this results in shutting down. Other than that, if you ran this for a while before you found the oil had run out, you might have seized the engine. Does it crank and turn over ok, but just not fire? Need more info here if you want more help.
    Hulld, AModelCat, wallance and 2 others Thank this.
  6. Derailed
    Derailed Road Train Member
    2,379
    2,648
    Dec 10, 2008
    Upstate NY
    A new filter that came without an O ring. Hmmmm
  7. blairandgretchen
    12,048
    60,659
    Dec 9, 2011
    South west Missouri
    Did you fill the oil filter with clean oil before replacing?
  8. wallance
    wallance Light Load Member
    66
    7
    Jan 12, 2018
    Hi sir,
    My truck is 2015 VOLVO 670 ,D13 Engine.
    Last Tuesday,When I am driving, it comes up STOP WARNING. Then it shut down.Many times!The oil pressure only 30, sometimes nearly 0.The oil looks like water and coolant decrease a lot.
    I have change fresh oil,everything looks good.Two days after now, I have run 1000 miles,and oil pressure go down 30 again! No warning yet.
    I saw somebody said might be the problem of radiator or Cylinder gasket ?Should I go to dealer right now?Thanks.
  9. Oldironfan
    Oldironfan Road Train Member
    5,777
    5,538
    May 22, 2017
    Volvo yup that's the problem.
  10. Heavyd
    7,626
    6,027
    Feb 4, 2009
    Yes, you better have that engine looked at by a mechanic who knows Volvo engines because it sounds like something is very seriously wrong with it.
    Broke Down 69 Thanks this.
  11. AModelCat
    145,367
    Heavyd Thanks this.
